Does an S2000 really spin/crash that easy?
And that said, shouldn't the answer be "Yes".
It's not asking whether these spins and crashes are caused by poor engineering or inexperienced drivers...
It's just asking if it's easier to spin and crash S2000s than other cars...and I think we all agree that the answer is yes...regardless of the root cause...
This car is no more spin happy than any other rear wheel drive car with a neutral balance.
Honda started dialing the oversteer out immediately after the first cars were sold in 1999 and at least every two years thereafter. A glance at the suspension component changes in the tech data (here), including wheels and tires, shows the hardware changes. The older model years spin out easier than the later, the 1999 cars having the most understeer.
As several have noted changes in alignment, tires, etc. affect this, but the typical first time S2000 driver hasn't a clue about these settings nor, I suspect, the majority of drivers here. My car was aligned to factory specs a couple of years ago and I'm running "extreme" performance summer tires (RE-11A at present). Haven't yet experienced a spin so perhaps I'm not pushing hard enough!
-- Chuck
-- Chuck
Originally Posted by RedCelica' timestamp='1457986369' post='23908301
[quote name='zeroptzero' timestamp='1457983755' post='23908233']
Part of the problem with Ap1's is that the rear toe changes significantly as the suspension unloads, and toe settings go toe-out, causing whacky rear end behavior - leading to snap oversteer. They addressed that issue on the Ap2 suspension on 2004+ models.
[/quote]
This. My ap1 is no more tail happy than any ap2 I have driven. Your don't even need bump steer correctors. If not setup right they can hurt more than help anyway. Want to make your "tail happy" ap1 a pussycat? This:
Ap2 tire, wheel package. This is almost all the handling improvement the stock ap2 has over the ap1.
Less rear toe than oem. Run the cr rear toe specs, should be around .30 degrees total.
Lower the car around an inch. This brings the oem toe curve into a more predictable spot. This with the above is the alignment sweet spot for ap1.
However.....
You need to have at least 1" of clear rear shock travel at ride height. This is before you hit the bump stops. 1" is the bare minimum, should be closer to 2.
YES YES YES lol Any car with such a short wheel base will be easy to spin out regardless how experienced you are. The question isn't if you have spun out but rather how the s2k is compared to others and I'll answer with yes. Regardless if youre a pro or not this platform is tons of fun but will bite you in the ass if you don't respect it.
Originally Posted by jamesac83
I disagree, it's not any easier to spin.. as was pointed out by someone else, harder to recover when a spin/slide is initiated is more accurate. It's a sports car, it is not easier to spin than other sports cars. Compared to a fwd family sedan, or a minivan, sure.
Most important is to have nice tires. I bought the car with "good" tires and spun coming out a turn in my first month of ownership.
After putting on some nice tires and a few years later I can do 110mph+ in rain with no problems.
You get used to the dynamics and limits of the car once you been driving it for a while.
