Does V-afc safe for S2000?
Old Jul 19, 2001 | 11:30 PM
Juila911's Avatar
Default Does V-afc safe for S2000?
I am going to install V-AFC this weekend.
Is it safe to install V-AFC on S2000?
Also, what rpm should I set it up for V-tech? 5000rpm-5500rpm.
i need some advice ASAP.
Does it avoid the factory warranty?
Old Jul 20, 2001 | 04:12 AM
shingles's Avatar
Please do a search... upper right of the page.
-Shing
Old Jul 20, 2001 | 05:40 AM
derryck's Avatar
It will void the warranty and VTEC should be set to 5600 RPM's. This should be tuned on a dyno when installed.
Old Jul 20, 2001 | 08:10 AM
Takashi KazuMori's Avatar
I wouldn't do it if I was you ... It's rarely done in Japan on an F20c for sure and I'll rather opt to change the whole ECU rather than just install the V-AFC thing. It's not that big of a deal changing the RPMs or the fuel controls, in my opinion.
Old Jul 20, 2001 | 11:26 AM
derryck's Avatar
Actually the V-AFC is the best 'bang for the buck' mod that I have seen to date. You can lower VTEC to 5600 RPM's and adjust fuel where needed. After mine was installed the VTEC transition was much smoother and I gained a fair amount especially in the high RPM range.
rikhemi
Jan 14, 2008 02:28 PM
Steve2K
Feb 25, 2002 12:52 PM
Wesmaster
Aug 15, 2001 05:27 AM
derryck
Jan 9, 2001 01:00 AM
mingster
Nov 14, 2000 07:21 AM
