Door/lights Chime
Old May 3, 2010 | 09:30 AM
SilversS2000's Avatar
Default Door/lights Chime
The Chime for my Door and Headlights only works part of the time. Sometimes when my door is open and keys are in the ignition it will be beeping steadily then stop beeping for a few minutes, then it will start beeping again. Sometimes it doesn't beep at all when I open my door when I have my lights on? What could cause this?
Old May 3, 2010 | 09:47 AM
Incubus's Avatar
What happens if you fasten the seatbelt? What happens if you remove it?
Old May 4, 2010 | 04:21 AM
I'm not sure. I will check tonight. What is it suppose to do?
Old May 4, 2010 | 04:37 AM
Elistan's Avatar
Probably the switch in the door jamb that tells the car when the door is open or closed. It gets filthy and the contacts don't always work. It just takes a regular philips-head screwdriver to take off, then it's easy to clean.
boyguan
Mar 2, 2023 12:12 PM
RedCelica
Oct 22, 2010 05:15 PM
SPLNDID
Oct 25, 2007 05:02 PM
txst
Aug 10, 2001 09:58 AM
lucid
Jun 25, 2001 03:34 AM
