Driveway Scrape
Old Aug 4, 2007 | 08:00 AM
Dex9's Avatar
Default Driveway Scrape
In the Bronx there aren't too many choices, I have an outdoor lot w/ a steep 'gully' to the street that is scraping as I pull in or out.
I tried going cross slope which helps, but I still seem to scrape one end or the other.
I haven't crawled underneath and looked, but I believe it's the chin/ air dam in the front and the exhaust(?) in the back, though perhaps it sounds like something worse.
Ques:
If I had to pick my poison, is it better to scrape in the front or rear?
(It's a public street, I can't fill the depression w/ anything)
Old Aug 4, 2007 | 02:05 PM
nightcrawler7188's Avatar
come out at a mean angle
if you scrape the front couldn't you be scraping the oilpan? it's not good to scrape either the front or the rear.
Old Aug 4, 2007 | 06:58 PM
00CivicSi's Avatar
The oil pan is essentially between the front tires (actually, just behind the centerline of the front wheels). Therefore, he's not scraping the oil pan on a 'depression.'
I'm willing to bet that the OP is scraping his front lip.
Old Aug 4, 2007 | 07:29 PM
oh yeah
Old Aug 4, 2007 | 09:14 PM
CKit's Avatar
Coastal Metals bumper protector, FTW!
Old Aug 4, 2007 | 10:13 PM
chuhsi's Avatar
I'd much rather scrape my front lip than my rear exhaust (which is what I'm guessing is happening.
A coastal metals front bumper protector may help. Then again, the "gully" may just rip it off your car.
Old Aug 4, 2007 | 10:32 PM
NFRs2000NYC's Avatar
I believe the oil pan on the s2000 is impossible to scrape. If I remember correctly, the side rails (where the jackpoints are) are 1-2" lower than the oil pan, so if you hit, you are going to hit the rails. (unless the bump/hump is only about 2-3' wide, then you can be in between the rails)....Now Vws/audis are another story. My friend cracked his oilpan three times on his jetta (he was dropped though).
Old Aug 5, 2007 | 08:45 AM
Dex9's Avatar
I'll check underneath, and post up
Old Aug 5, 2007 | 09:56 AM
Paul S's Avatar
If you're scraping, you should just take off your front lip. But like others have said, I'd rather scrape up the front lip than the exhaust. I used to scrape in my driveway, too, but if you take it slow at a 45 degree angle, you should be able to clear most bumps.
Old Aug 5, 2007 | 10:07 AM
JetBlackS2000's Avatar
my car is slammed and i avoid scraping at all costs even if it means backing up, u-turn and finding an alternate route...it helps a lot that my coilovers are set to very stiff...maybe try finding another parking lot
DavidDao77
Jul 18, 2013 06:13 PM
amkaluta
Feb 10, 2009 09:22 PM
pdexta
Jul 15, 2007 07:35 PM
s2addict
Feb 12, 2007 10:06 PM
