dropping out of VTEC when shifting
The reason it appears the car stays in VTEC is because: 1) clutch is slipping due to CDV allowing the engine to rev but not transmitting power; 2) tires break loose, which again allows the engine to rev but no power to the ground.
Note...there is also a delay in the rev counter. It lags behind the actual rpm.
The calculator is based on the gear ratios and is correct.
Originally Posted by Saki GT' date='Mar 20 2007, 09:09 PM
Look, believe whatever makes you feel better, but I'm in an AP2 and I (and lots of other AP2 owners) can tell you the car stays in Vtec.
Hell...there is a video showing the s2k at 175mph on the speedo...but that isn't accurate either...the gearing limits the car to 170mph if tire deflection is not taken into consideration and 166mph if deflection is considered.
The math is accurate and objective. Your rpm gauge and feelings are not.
[quote name='negcamber' date='Mar 20 2007, 05:05 PM'] The reason it appears the car stays in VTEC is because: 1) clutch is slipping due to CDV allowing the engine to rev but not transmitting power; 2) tires break loose, which again allows the engine to rev but no power to the ground.
And you as well...believe that David Copperfield really did make the Statue of Liberty disappear if you like to.
