dropping the top without engauging handbrake
Old Mar 15, 2005 | 12:53 PM
MC21's Avatar
Default dropping the top without engauging handbrake
Im sure this has been talked about before, but the search thingie is not working too well.
so....can this be done?
can someone lead me to that thread?
Old Mar 15, 2005 | 12:55 PM
Cyclon36's Avatar
yes, it can be done. There is a wire you disconnect under the dash on the passenger side. The only drawback is that the E-Brake light stays on if you do that. The best way is to disconnect the speed sensor. That way you only have to raise the brake one click, then you can put the top up/down while moving.
Here's a link: https://www.s2ki.com/forums/index.php?showtopic=138773
Old Mar 15, 2005 | 02:06 PM
MC21's Avatar
thanx Cyclon36!
Old Mar 15, 2005 | 03:57 PM
ruexp67's Avatar
Actually the wire under the dash IS the speed sensor wire. You will need to disable that no matter what you do.
To disable the handbrake safety you would disconnect the wire attached to the base of the handle under the center console. As mentioned above the BRAKE light would stay on all the time.
I clipped the wire under the dash (takes less than 1 minute) then all I have to do is "one-click" the handbrake to make it work (the handbrake is NOT engaged with just one click so you can do it while moving.)
s20001988
Apr 20, 2012 10:23 PM
s20001988
Apr 11, 2012 02:39 PM
nazaracing
May 7, 2005 02:04 PM
PENROD
South Florida
Jan 11, 2005 06:02 AM
scubasteve
Oct 11, 2004 05:14 PM
