Dyno Numbers
Old Oct 19, 2006 | 08:05 AM
Johnny Sack's Avatar
Originally Posted by AssassinJN,Oct 19 2006, 07:47 AM
That is the standard vtec engagement from what I've seen. The engagement is actually set a little later than optimal just for that reason, so you feel vtec engage. Get a vafcII, or if you budget allows an aem ems and some tuning time and move your vtec engagement down some (most seem to suggest between 300 and 500 rpm sooner) and you'll get a much smoother more linear engagement. You'll also net another 10 or so hp and tq, although you'll have to reset your ecu around once a week with the vafc.
You shouldn't worry as is though, as previously mentioned, you're right in the norm.
if you tune your vafc to only modify AFR at WOT then you never have to reset the ecu
Old Oct 20, 2006 | 08:58 PM
Pawan's Avatar
During WOT the ECU goes into closed loop and will not retune itself. (it will for partial throttle).
Old Oct 21, 2006 | 05:02 AM
S2KPUDDYDAD's Avatar
My AP1 is right around the same on the same type of dyno
This is a few years ago stock car with a K&N filter. On a hot Florida day
Old Oct 21, 2006 | 06:41 AM
wildcardtrd's Avatar
Everything looks stock to me. Now start opening it up!
Old Oct 21, 2006 | 07:56 AM
gomarlins3's Avatar
Seems normal to me. I was 191 with an AP1 when I was fairly stock.
juntuned
Mar 24, 2009 11:22 AM
707S2K
Aug 29, 2008 08:36 PM
spider2k
Oct 13, 2005 07:41 AM
