Easiest way from trunk to the inside?
Old Jan 7, 2004 | 10:39 AM
ScottB's Avatar
Default Easiest way from trunk to the inside?
What is the easiest way to run a wire from inside the trunk to the interior of the car? I have a very small antenna wire from XM that I'd like to run from the trunk (inside, not out) to the unit inside of the car. Is there a relatively easy way to get to the inside from the trunk?
Thanks.
Old Jan 7, 2004 | 10:47 AM
payyourtoll's Avatar
just remove the panel on the pass side of the trunk, covering the spare.
pull the pass seat forward and remove the panel behind the seat. now run the wire from the trunk thru this opening.
that's just to get the wiring in the car. you will see how you can run the wire behind this area. If you have to get it up to the radio, unclip the push-pins on the side of the console, so you can snake the lines up under this console cover. Just be sure to push the wire up high enough so the push pins will sit below the wire under the console cover.
if you need to reach the radio, take the philips screw out of the pass side knee pad and gently remove it, and you will have access to feed the wire behind the radio.
sorry if anything here sounds too obvious, wasn't clear on exactly what you needed.
3ngin33r1's Avatar
Pop the rear panel off on the side your spare is on. There's you're trunk.
Old Jan 7, 2004 | 10:48 AM
3ngin33r1's Avatar
Damn! I'm too slow today.
Old Jan 7, 2004 | 10:49 AM
Old Jan 7, 2004 | 01:24 PM
ScottB's Avatar
Thanks a lot guys. It likely was obvious, but not to me. I didn't want to make this anymore complicated than I needed to.
Many thanks.
Old Jan 7, 2004 | 04:36 PM
3ngin33r1's Avatar
anytime.
Old Jan 8, 2004 | 04:38 PM
KenS2K's Avatar
Hi Scott!
The CD changer install instructions has details on how to remove the proper panels and such. HandA has the PDF on their website.
http://www.handa-accessories.com/S2000/s2k...2kcdchanger.pdf
yetanotherbrian
Nov 11, 2015 06:38 AM
Ed'sS2000
Nov 9, 2014 08:00 PM
whythot
Feb 23, 2006 07:27 PM
WPS
Aug 9, 2005 04:37 PM
amartin
Dec 14, 2001 10:34 AM
