Few S2K questions
Old Dec 30, 2007 | 09:53 AM
robodeath's Avatar
Default Few S2K questions
1.) At around 60mph with my top up, the wind noise gets REALLY loud. I think my top isn't sealing good at the front. When I pull the front of my top down the noise goes away. Any way I can tighten the clamps that lock it down? Or maybe add some weather stripping to it?
2.) I know you can turn the radio on and change from AM to FM to CD from the button on the left of the steering wheel, but why doesn't it/can I make it turn the radio off from that button?
3.) While daily driving, what rpm do you generally shift at?
Old Dec 30, 2007 | 09:59 AM
Dan H's Avatar
1) Replace your strikers with hardtop strikers. You can get them from hardtopguy.com for around $50 or so shipped.
2) Not sure, I'll have to check.
3) 3-4k rpm.
Old Dec 30, 2007 | 03:50 PM
ace123's Avatar
2/ i cant on my car, but the 06 stereo may be different. i just mute it.
3/ 3.5-4.5k is typical for me, but mine redlines at 8k, not 9k. i'd probably shift at about 4.5-5k with an ap1 just to get more power.
Old Dec 30, 2007 | 04:02 PM
DarkShade9's Avatar
I think there's a mod to increase the functionality of the knobs, but mine just changes from AM/FM/CD with a push.
Old Dec 30, 2007 | 04:39 PM
y4ngel's Avatar
2) Just mute it
3) 3500 - 4500, unless I'm in a hurry! (AP2)
Old Dec 30, 2007 | 06:06 PM
mikeyr's Avatar
on my 07, if I hold the little volume bar downward long enough it "Beeps" after 3-5 seconds and then the radio is off, I found that I was muting it most of the time. Now I finally have no radio since my radio had a problem and would come on every now and then even though I had it turned off. Dealership is going to replace the radio but its been 3 weeks with the radio out and I am finding I like it and could make a cool little space to store change,etc.
AFTER (note the CAPS) AFTER its warmed up, I shift between 5,000 and 5,000 RPM always unless going into VTEC, I come from the world of Italian high revving toys where the motor is designed to spin about 60% of its redline, with my S having a 8,000RPM redline that means I keep it at 4,000-4,500 at all times, I have to shift above 5k to keep it there. The one exception is long distances on the freeway, I go into 6th and let it spin slower for better mileage and motor longevity.
Old Dec 30, 2007 | 07:30 PM
Drkphnx's Avatar
1. mine does the same thing, but im usually top down. your catchers may be worn. not sure how much new ones are.
2. i agree, mute it
3. i shift at 9k
Old Dec 30, 2007 | 07:52 PM
s2knOOb02's Avatar
1. top always down!
2.mute it!
3.bout 5000 AP1
Old Dec 30, 2007 | 07:56 PM
S2k Dude's Avatar
1) Hardtop strikers or do the trick with adding some tubing around the latch hooks.
2) I've never been able to turn the radio on/off with the dash controls.
3) Around 4,000 RPM in normal driving.
Old Jan 1, 2008 | 05:23 PM
gomarlins3's Avatar
Originally Posted by y4ngel,Dec 30 2007, 07:39 PM
2) Just mute it
That was going to be my suggestion as well.
mhdelano
May 9, 2009 09:14 PM
Dr Col
Aug 12, 2007 11:39 AM
glxyjones
Mar 26, 2007 12:44 PM
djohnston
Mar 15, 2001 10:09 PM
