Final Gears?
Old Mar 18, 2006 | 08:38 PM
roadster_s2k's Avatar
Default Final Gears?
What is a final gear? 4.6, 4.9. etc.
Old Mar 18, 2006 | 08:39 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Mar 18, 2006 | 08:43 PM
yeah wut is that? what are the numbers? How is it different with stock? (what is stock #)
Old Mar 18, 2006 | 08:51 PM
vbb's Avatar
vbb
Dude, not to be mean, but you've started up three or four posts in the last hour or so asking questions that have been answered hundreds of times already. This site has a lot of info... spend some time reading first, and if you still have questions, ask then.
Old Mar 18, 2006 | 08:52 PM
pdexta's Avatar
It's like a 10 speed bicycle. Your normal car only has gears 6-10 (using all of the back gears but only the big front gear). This is the stock 4.1 gear.
Now you install shorter gears on your car (4.44, 4.57, or 4.77). On your bicycle you can now only use gears 1-5. Your bicycle now has a lower top speed, better acceleration, and you have to run higher RPMs to attain the same speed.
That is final gear.
Old Mar 18, 2006 | 08:54 PM
S2KSpaYellow's Avatar
The number is the ratio of ring gear teeth to pinion teeth. Basically with stock 4.10 gears the driveshaft will turn 4.10 times to 1 turn of the wheel. An aftermarket set of 4.56 would accelerate better, but have lower top speed. A 3.75 set would have a slower acceleration, but a higher top speed.
Old Mar 18, 2006 | 08:56 PM
so basically for city driving and stop and go, higher aftermarket sets are better. THanks
Old Mar 18, 2006 | 09:03 PM
Stratocaster's Avatar
It is a ratio. 4.10 to 1. For each revolution of the output shafts (to the tires) the propeller shaft has to rotate 4.1 times. So with a 4.57 ratio, the propeller shaft has to rotate 4.56 times.
Stock is 4.10.
attack666
Aug 26, 2007 03:50 PM
freshSofVa
Apr 11, 2006 11:30 AM
passmans2kny
Apr 6, 2006 05:42 AM
Mr. Francesco
Jul 18, 2004 07:42 AM
NoMoreWRX
Feb 21, 2003 07:39 PM
