Flywheel
Old Oct 24, 2005 | 03:25 PM
Silver9k's Avatar
Originally Posted by Intrepid175,Oct 24 2005, 01:22 PM
My car is still stock. Going to a lighter flywheel is something I've thought I might try when I "need" to replace the clutch but probably won't go to the trouble before that.
When you're talking about accelerating a given amount of mass to 9k rpms, lighter is obviously better but I haven't a clue what the actual hp improvements would be.
I found your comment on rev matching interesting. One of the biggest problems I have with rev matching (I'm talking down shifting here) is that the engine revs so quickly that I usually overdo it. A lighter flywheel would only make that problem worse which is why I'm not totally convinced it's something I want to do.
FWIW!
Drive Safe,
Steve R.
Ya I got mine done with the clutch TSB, so it was good. And ya I'm sure it probably does free up some hp...but the butt dyno wasn't that convinced.
As far as rev matching...personally, to me it makes it easier because it just takes a very quick stab of the throttle then into gear and slip the clutch, all within that second...just modulate the gas a little better I guess, maybe this would make it easier for you as well since it would be more "touchy" per se. All you'd need is that quick stab instead of the longer stab...idk what I'm talking about anymore
Old Oct 25, 2005 | 12:41 PM
MmphsS2000's Avatar
So, should I not get one? Or should Iwait til' I replace the Clutch? I really don't want to hurt my acceleration (0-60), will getting a flywheel really hurt my 0-60???
Old Oct 25, 2005 | 01:28 PM
Intrepid175's Avatar
[QUOTE=Silver9k,Oct 24 2005, 05:25 PM] As far as rev matching...personally, to me it makes it easier because it just takes a very quick stab of the throttle then into gear and slip the clutch, all within that second...just modulate the gas a little better I guess, maybe this would make it easier for you as well since it would be more "touchy" per se.
gt489
Nov 8, 2007 07:16 PM
bunjimobile
Sep 15, 2006 09:53 AM
kfdon
Jul 2, 2006 07:10 AM
nrowe
Nov 26, 2005 05:01 AM
animeS2K
Dec 4, 2000 12:00 PM
