Forgot to plug washer on differential drain plug
Old Aug 23, 2007 | 08:11 PM
mew002's Avatar
Default Forgot to plug washer on differential drain plug
I don't have enough differential fluid on me at the moment to take out the plug and put the washer back on so would it be problematic to drive the car for a day without the washer? The earliest time I can put the washer back on is after work tomorrow at 6pm. Thanks guys.
Old Aug 23, 2007 | 08:47 PM
JstnRyan's Avatar
As long as you have a good seal with the drain plug alone, you will be fine. Just don't let it get too low (and drive) if you're seeing seepage.
Old Aug 23, 2007 | 08:54 PM
mew002's Avatar
Sorry I did not quite comprehend "seeing seepage" at the end of the second sentence. I've torqued it to 33 lbs as stated in the guide so hopefully that'll help a bit.
Old Aug 23, 2007 | 09:35 PM
SIIK2NR's Avatar
The washer is what actually creates the seal. The head of the bolt will do so temporarily, but you should get the washer on there soonest.
Old Aug 23, 2007 | 11:36 PM
JstnRyan's Avatar
Sorry that I was unclear. To be as precise as possible:
(Like SIIK2NR said You need the washer to create a seal. In my opinion, you are okay to TEMPORARILY drive the car without the washer as long as there are no signs of seepage (leakage) from the bolt.
NotaMechanic431
Jun 8, 2016 09:56 PM
soon2bspooled
Oct 17, 2011 05:41 PM
JSR_AP2
Dec 4, 2004 03:46 PM
DJHohum
Apr 27, 2002 07:04 PM
