Gas overflow
Old Jan 11, 2009 | 04:49 PM
ts80's Avatar
Default Gas overflow
Not sure if this is the correct forum category...
Two times in a row at two different gas stations my gas tank overflowed. Usually the automatic shut-off at the pump clicks when it's full, it didn't do it the last two times.
Is there anything mechanical about the S that helps the fuel shut-off at the pumps? Or is it just my luck that I hit two bad pumps at two different gas stations?
btw, the first pump I had issues with was at a gas station I've often filled at...don't recall if I've ever used that specific pump though.
Any help or insight is appreciated. Thanks.
Old Jan 11, 2009 | 05:29 PM
99bb6's Avatar
i couldnt tell you about the s having something that aids the gas to shut off but i bet it was just luck
Old Jan 11, 2009 | 06:11 PM
zoomkat's Avatar
Probably just problems with the gas nozzle. The nozzles have a neat little vacuum feedback setup that should trip the nozzle latch when the tip of the nozzle submerges in the gas in the filler neck. If it keeps happening make sure the nozzle is fully inserted in the fill neck and maybe fill at a slower rate.
Old Jan 11, 2009 | 06:25 PM
DFWs2k's Avatar
make sure you are sticking the nozzle all the way in
Old Jan 11, 2009 | 07:44 PM
gshoq's Avatar
Maybe you can try lifting the nozzle a bit during filling?
Old Jan 11, 2009 | 10:24 PM
terahertz's Avatar
mine does this about 25% of the time. i always just grab those free paper towels and bundle it up underneath the nozzle
Old Jan 12, 2009 | 07:11 AM
craig2teg's Avatar
Yea as others have posted just make sure the nozzle is in all the way. The same crap happened to me a few times last year. The most recent one I had a Dumb & Dumber momment . "f'n embarrassing"
AP1EM1
Oct 10, 2011 02:26 PM
dn7309
Feb 5, 2010 06:32 PM
HonCBRf2
Sep 15, 2008 12:42 PM
Killship
Jul 10, 2007 06:42 PM
Sfkn2
Jul 2, 2006 09:19 AM
