Get I get some tips!
Old Aug 9, 2007 | 08:00 AM
__redruM's Avatar
[QUOTE=Elistan,Aug 9 2007, 10:14 AM]Talk to these guys.
Old Aug 9, 2007 | 08:12 AM
e3opian's Avatar
There's one of these in the club I autocross with. Very fast car...
Old Aug 9, 2007 | 08:24 AM
lotus7racer's Avatar
Originally Posted by rotorhead1986,Aug 9 2007, 09:49 AM
This thread is worthless without pics! Lets see some of your Lotus!
My 3 Lotuses.
Currently I have a Hayabusa Tubocharged in the seven.
I'm going traditional setup.
Old Aug 9, 2007 | 08:31 AM
[QUOTE=Wildncrazy,Aug 9 2007, 09:46 AM] I have been "involved" with several S2000 7s. If you can fit it to your dash supports the whole S2000 dash will transfer and wire up.
There will be a few buttons you don't need but it will work and in my opinion is better than many aftermarket gauge packages.
Old Aug 9, 2007 | 10:15 AM
MikeyCB's Avatar
Originally Posted by lotus7racer,Aug 9 2007, 10:31 AM
I don't know if I have enough room for small catalytic converter but I have to do what I have to do. I wish I can delete it.
Is His name Brian Anderson? (his name sounds familiar)
Some kind of resistor in line to defeat the immobilizer? I will contact the guy.
Million thanks..
You can delete the cat. Simply pull the secondary O2 sensor out of the direct stream of the exhaust air so it picks up a far reduced amount by being out of the flow path. Since you'll clearly be going with a custom exhaust, drill a small hole in the exhaust pipe and weld a 2 inch threaded tube over the hole and screw the O2 sensor into it. Voila!
Old Aug 9, 2007 | 10:43 AM
Sorry I haven't seen the 2 o2 sensors for the s2000
Is the secondary 02 sensor at the end before the tailpipe?
You mean, install the secondary far enough to fool the ecu?
Old Aug 9, 2007 | 10:58 AM
toofast4yalll's Avatar
Owning 3 British cars, you must be pretty familiar with Lucas electrical systems. :thumbsdown: lol. I'm just kidding, I can't say anything bad about Lotus. I drove an Exige last week, it handled like a shifter kart.
Old Aug 9, 2007 | 11:38 AM
MikeyCB's Avatar
The secondary sensor is supposed to be following the cat to ensure it is functioning properly and reducing emissions.
Exactly, pull the sensor far enough that it is picking up a reduced amount and the ECU will believe everything is okay and that the cat is still there and doing its job.
Louisq
Aug 10, 2015 08:38 AM
Mr. Francesco
May 18, 2013 07:00 PM
dagle
Apr 9, 2013 08:16 PM
BrianGT
Jun 14, 2006 12:09 AM
