Glass Window Recommendations?
Old Dec 25, 2001 | 02:41 PM
Maggie's Avatar
Default Glass Window Recommendations?
I just ordered a red 2002 S2K. It arrives in March. I have seen the posts on the plastic windows that recommend the roof well mat and the window tube to prevent scratching. Is this something I should invest in to protect the glass window as well????
Old Dec 25, 2001 | 03:09 PM
DarioManfretti's Avatar
Others will probably be able to help you out better, but I would say you shouldn't have any problems with scratching like those of us pre 2002 owners. Probably just keep the window clean.
Old Dec 25, 2001 | 03:36 PM
same's Avatar
I don't think you need to worry about that. I have a 02' S2000 and it was worth the wait!
The rear window is much smaller and takes down some of the rear visibility. But if you drive fast enough all you need to see is in front of you.
Old Dec 25, 2001 | 05:31 PM
JonasM's Avatar
I went for another test drive this past Saturday. In the process, I had a look at how the window behaves on raising & lowering the top. At the bottom position, it ends up still sitting up at an angle, so it's never flat against the well or other parts of the top. Looks like it's safe from scratching, as far as I could see.
JonasM
Cataclysm
Nov 27, 2005 06:29 AM
S2KRAY
Apr 7, 2004 05:49 AM
lostsol
Oct 10, 2002 12:21 AM
marcucci
Sep 19, 2001 07:11 PM
GT2000
Jun 22, 2001 09:33 AM
