Got my car back from the service bulletin
Old Oct 16, 2000 | 11:24 AM
Fito's Avatar
I got my car back, Honda installed mugen clutch and Toda flywheel ( $137.00 install cost) and they did the bulletin thing on the trany. So far everything is perfect, the clutch is as smooth as factory but the engagement feels bit stronger. The flywheel WOW what a difference, now at low RPM the car is much easier to drive and seems like it has torque. I haven't driven it hard because of the break-in on all the new parts.
Old Oct 16, 2000 | 11:38 AM
Fireslayer's Avatar
I'm wondering if the 2001's will have the updated clutch assembly.
dave
Old Oct 16, 2000 | 11:43 AM
S2KnOrlando's Avatar
How much for the clutch and flywheel? Im having mine fixed in a couple of months.
Old Oct 16, 2000 | 11:46 AM
Fito's Avatar
Well the Mugen clutch go's for $399.00 and the flywheel is around the $350 range.
Old Oct 16, 2000 | 11:52 AM
Thanks Fito, It will be interesting to see how much my dealer will charge for the install when they do the tranny work.
Old Oct 16, 2000 | 01:02 PM
S2000 Driver's Avatar
Fito,
I'm considering doing the exact same thing you did when I get my car serviced for the 1-2 Shift Grind problem.
I called the Service Manager at the Honda Dealership where I purchased my car, and informed him of what I proposed to do; i.e., replace the flywheel with a Toda unit and the clutch with a Mugen unit at the same time they perform the Bulletin fix.
He said he would not risk voiding my warranty unless he received prior approval from the District/Regional Honda Corp. Service Manager.
Did you run into these concerns as well? If so, how did you address them?
Please advise. Thanks.
Old Oct 16, 2000 | 01:40 PM
Fito's Avatar
Well, at first Pepe had a bit of problems when he whent to install his clutch, but I whent and talked to my guy over there and had no problem. They just charged me the time they spend installing these two parts.
JayStyles662
Dec 10, 2006 07:48 AM
REVHARDSILVERSTONE
Nov 20, 2005 07:25 PM
simonprelude
Feb 2, 2005 08:06 AM
spesrf25
May 4, 2004 01:48 PM
HondaGuy
Nov 14, 2000 09:16 AM
