Handling question
Old Apr 26, 2006 | 01:23 PM
Suzukaboy's Avatar
Default Handling question
Got about 6k miles on the car, stock, original tires. Would estimate about half tread left on rears and more on the fronts. Very occasionally, like once a month or so, I notice that when taking a fairly tight but sweeper type corner (50-60mph) the wheel does not unwind totally smoothly. Almost always it is a corner were I can hold the wheel in a steady position until I want to start unwinding it. At that point the wheel resists the first effort to unwind it like the tire was in a groove or the steering somehow took a set. A little more effort and it unwinds smoothly and normally. It's not a big effect but I can feel it. If I was feeling it more often I would suspect something in the steering but most of the time it feels fine.
Anybody else see this or have an idea?
Old Apr 26, 2006 | 02:00 PM
Alexei's Avatar
If this is a new car, are you sure the dealership removed the front & rear spring spacers (thick rubber between the springs)?
When I bought my car the dealership "forgot" so I drove it about 1400 miles until I noticed the gap from the top of my wheel to the fender was larger than another S2K in the neighborhood.
With the spacers in the car, I thought the handling was OK, but the ride stiff... Now with the spacers removed (as they should be) the ride is noticeably softer AND I can hang in corners better than before... Imagine that!
Old Apr 26, 2006 | 04:10 PM
Enthralled's Avatar
also check for nails and check tire pressure too
Peace
David
Old Apr 26, 2006 | 08:02 PM
RED MX5's Avatar
[QUOTE=Suzukaboy,Apr 26 2006, 04:23 PM]Got about 6k miles on the car, stock, original tires.
Old Apr 27, 2006 | 07:23 AM
Suzukaboy's Avatar
Originally Posted by RED MX5,Apr 26 2006, 08:02 PM
Checking to make sure the spacers were removed, and checking the tires for damage and proper pressure are good ideas, but I don't see how either could cause the kind of stiction you describe. I haven't seen this before, but it is certainly not normal. If nobody comes up with an answer and Billman doesn't respond I'd suggest sending a PM to Billman. If it's happened to anyone else's car he's probably aware of it.
Sorry I can't be more helpful.
I'll check the spacer thing. I'm beginning to think it might be one particular spot in the steering that is binding up if I happen to stop at that position. I PM'ed Billman. Thanks for the idea.
Old Apr 27, 2006 | 09:53 AM
dmz's Avatar
dmz
If you were turning at almost full lock, then the initial resistance to unwind is normal. What's hapenning is that your front wheels are almost side way and the force is forcing your wheels to go to the opposit direction from the unwinding direction. This happens everytime aon almost every car I've driven when I take a fast U turn.
Old Apr 28, 2006 | 02:15 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Put it in the air and feel the steering by hand. Sounds like someone hit a curb at one point and damaged the rack. Pop the tie rod ends and steering coupler and isolate the rack. Should be real easy to find at that point.
SlipAngle79
Oct 22, 2008 09:13 AM
rikhemi
Aug 10, 2006 07:48 PM
teamking
Feb 10, 2005 04:41 AM
AZDavid
Nov 24, 2004 12:24 PM
catfish
Apr 3, 2004 07:20 AM
