Hard acceleration on wet
Old May 6, 2008 | 02:02 AM
  #31
Popeye's Avatar
If the OP had started the thread.........
"my last three autocrosses were in the wet and I'm getting wheel hop at the start"
Would you guys be flaming him ?
There are many reasons for wheel hop and since there is no known rear traction bar set up for the S2000 try first by playing with tire pressures.
Several manufacturers make hard bushings for the rear attachment points (Spoon.Mugen,ect..) that maybe your next move
Let us know if you found a solution
Old May 6, 2008 | 02:51 AM
  #32
jurn's Avatar
I think you should stop driveing like a jackass Why can't people just answer the question instead of giving driving lessons.
I used to have an 200sx (european equivalent of the 240sx but with a different engine). I often got wheelhop. Not in the wet though, but on dry asphalt. It is a common problem with these cars because the bushings in the rear subframe are to soft. So taking a look at tire pressure, shocks and bushings is probably the way to go.
What pressure do you run in your tires?
Old May 6, 2008 | 03:48 AM
  #33
cmn's Avatar
cmn
Hehe. I normally don't drive like a jackass on wet, but sometimes it's too tempting.. And it seems like a lot of people here think that a bit of acceleration is driving like a jackass... If so, then yes I do!
I don't remember the tire pressure, but I do remember it was quite close to the maximum of what's written on the side oft them. I won't be able to check until next friday. I'll follow your advice/suggestions jurn, and check the tire pressure, and bushings. Maybe Powerflex is the way to go?
Old May 6, 2008 | 03:51 AM
  #34
cmn's Avatar
cmn
Thanks for the tips Maybe some harder bushings is the way to go. I'll do some testing with tire pressure as well, next time it's raining/wet.
Old May 6, 2008 | 07:17 AM
  #35
jurn's Avatar
BTW i run about 35 psi in my rear tires and have never had any trouble with wheel hop. Think we have about the same tire size as well. 255/17/40
Old May 6, 2008 | 08:17 AM
  #36
SheDrivesIt's Avatar
That may be your problem. If I recall, max pressure on the side wall on the OEM tire is about 45 PSI. That would be rock hard. Optimum recommended pressure is only 32 PSI. I doubt many run much more than 34 or 35 cold on the street.
Old May 6, 2008 | 09:13 AM
  #37
jlstyle82's Avatar
Hmm...
I guess you got some balls. I would crap my pants if someone drives my S under VTEC in rain when I'm on the passenger seat.
Maybe only because I spun the hell out of my car in rain and facked up the suspension before....
Old May 6, 2008 | 05:00 PM
  #38
RED MX5's Avatar
Originally Posted by cmn,May 6 2008, 03:21 AM
The shocks feel good in when driving, but I'll check them and also take a look if I can find some bushing that needs to be replaced.
I spin my tires too often, and have never seen the first sign of wheel hop, and it's certainly not normal with this car. Could be any number of things, but since you have an older car, I'd start by checking the shocks and bushings. Could also be tires, wheels, or alignment, so just give everything a good inspection while you have the car up in the air. I know this is probably a stupid question, but is it possible that your wheel hop is being caused by a bumpy surface?
Old May 6, 2008 | 05:01 PM
  #39
RED MX5's Avatar
Originally Posted by jlstyle82,May 6 2008, 12:13 PM
Hmm...
I'd crap too, if somebody else did that kind of crap in my car, but it's different when I'm doing it.
Old May 10, 2008 | 10:11 AM
  #40
cmn's Avatar
cmn
Thanks. I'll check as soon as I can.
