header(s), not worth the money?!
Originally Posted by gomarlins3,May 29 2006, 07:06 PM
no ricks header is supposed to gain you 6hp 4 tq in the mid range and 1-2hp on top. The dyno graph shows a loss of HP top end beause they bolted it right back onto the dyno after the header install and no driving around.
Would like to see another ricks dyno
Originally Posted by SilverKnight,May 29 2006, 10:26 PM
if your goign aftermarket header make sure you have a heat shield or vented hood.
I have both.
I have both.
I never did a dyno before I had the header, so I don't know what the difference was. The dyno I did do after it was put on looked very similar with the same results as the one posted in the link.
Those results are too close. Not to burst anyone's bubble, just making an observation. Keep in mind dyno results can fluctuate by 1% add to that heat issues and ECU reset(if applicable), things could be a wash.
megan header manufacturer dyno
http://putfile.com/pic.php?pic=1/3016270132.jpg&s=x2
search button is your friend!
nobody has actually dynoed it in real life yet.
Originally Posted by bkmagby,May 30 2006, 10:06 AM
Sorry, I looked at the graph wrong. You lost 3 hp and gained 3.5 ft/lbs of torque.
Version, do a Megan dyno! I'm hoping it's close in performance to J's so I can swap. But god damn, the J's sure is purty
rugsr
29
Nov 28, 2010 09:00 AM
