Help with 04 radio door please
Old Feb 20, 2004 | 08:04 PM
S2KHHI's Avatar
Default Help with 04 radio door please
Just recieved my radio door in the mail, wondering if anyone online knew how to easily install it, I would like to install it tonight but am not sure how, thanks if anyone can help!
Old Feb 20, 2004 | 08:22 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
PM Bobbyb he has done it....
Old Feb 20, 2004 | 08:26 PM
Shodan's Avatar
Open the door. Pull down unitl the entire housing comes loose. This takes quite a bit of pressure. Then work your way around until it is completely off.
I took a small drill bit, placed it where the pins are in the hinge. Others have used a coat hanger, but it didnt work for me. I used a drill bit and drill that was about the same size as the pin (It is hollow). Put the bit through, turn on the drill and angle it to create pressure and pull out at the same time. It is tricky.
There is a small spring on the left side (Facing the door) that allows the door to open slowly. DONT LOSE THIS.
Put back the same way.
I just did mine this week.
Steve
Old Feb 20, 2004 | 08:44 PM
hyun83's Avatar
The hardest part was taking the small drill bit out... i dont have any tools.. and the coat hanger took forever!
Old Feb 20, 2004 | 08:46 PM
Shodan's Avatar
I just turned on the drill with the bit through the hole, applied pressure to the outside while pulling out.
Steve
Old Feb 20, 2004 | 10:28 PM
PortugueseS2K's Avatar
I too tryed the paper clips and coat hanger to no avail i will try the small drill bit though, thanks for the tip
Old Feb 21, 2004 | 06:13 PM
Shodan's Avatar
Make sure it is big enough to just barely fit through. As you turn on the drill, angle it a bit to catch it, then pull easily out (I did it fast but smoothe)
Regardless, the inner pin should spin once it is grabbed onto by the bit.
Steve
Old Feb 21, 2004 | 06:47 PM
wortham's Avatar
the coat hanger worked well for me. use only that last little bit that actually does the hanging and break it off. then straighten out that end, fit it in the hole, and wad up a rag and put it on the end and push. when you're done (and not thinking it will actually work), you'll end up with a nice, round, bloody spot on your palm just like me. just got mine on thursday.
cRAVeN MoOrEhEaD
Jun 14, 2005 05:26 AM
localizer11
Mar 11, 2004 11:50 AM
robs_silver_s2k
Feb 19, 2004 03:33 AM
MB06
Feb 9, 2004 09:03 AM
StarvinMarvin
Dec 13, 2003 06:14 AM
