HELP
Old Jul 24, 2007 | 02:09 PM
skyteg's Avatar
Default HELP
Hi guys i need the info thats on the tag which is located on the inside of the car when you open the door on the driver side. This would be for a MY00.
The info is something like, gross weight front rear axles.. something like this..
Thank you very much
Old Jul 24, 2007 | 03:30 PM
skyteg's Avatar
no one?
Old Jul 24, 2007 | 03:55 PM
radcliffe1's Avatar
I'm confused. Would it not be appropriate to go out to your car and look at it? I don't know whats on yours.
If you're wondering what it all means check your Owner's Manual for an explanation.
If you don't have that - post the info up here and we'll translate it.
Just a thought.
Old Jul 24, 2007 | 03:59 PM
skyteg's Avatar
i know, the problem is i don't have that info. And i thought it was the same for all s2000.
A more precise question would be. I need the weight, the ratio of the weight in front and in the rear, and front and rear oem tire sizes, and the spare tire size. Also with the correct PSI ok KPA.
thanks
Old Jul 24, 2007 | 04:02 PM
brykel's Avatar
I'm sure a lot of people are bypassing this thread because of the non-descriptive title...just posting "HELP" doesn't help you at all...try editing it with a more descriptive title/subtitle so people with the info you want will click on it...
In the stickies:
https://www.s2ki.com/forums/index.php?showtopic=352908
Old Jul 24, 2007 | 04:06 PM
radcliffe1's Avatar
These are questions I don't know the answer too in that I think it varies (slightly) thru the years.
I think PSI is 32. I know the spare is a spacesaver and only fits the front.
The OEM tire size you can get by going to www.tirerack.com and entering your model year.
Old Jul 24, 2007 | 04:46 PM
bigsley18's Avatar
is this a result of your car being painted? i noticed your file says "custom color".
Old Jul 24, 2007 | 05:16 PM
__redruM's Avatar
What a usless topic. I know you could do better.
Curb weight is 2809lbs or 1274kgs
Divide by 4 for the individual tire weight. This should be close, since it's a 50/50 weight balanced car. Tire sizes:
Bridgestone Potenza S-02,
205/55VR16 / 225/50VR16
Inflate to 32psi
If you go with a different brand tire, note that the 225 on the rear is really closer to 245.
http://en.wikipedia.org/wiki/Honda_S2000
Old Jul 24, 2007 | 05:21 PM
skyteg's Avatar
that's all good thanks alot, yes it's because the car was painted
01S2KBROSNAN
Jun 12, 2010 08:04 AM
xxlap1xx
Sep 13, 2007 05:38 PM
JMH
Apr 1, 2007 08:51 PM
Ketchup2Me
Oct 22, 2006 09:20 PM
boostjunkie
Apr 7, 2006 05:03 PM
