I wanna jucie my 01 S with some nitrous but i dunno wat everyone recommends for the s2k i dont wanna spray that much just want like a 50 shot for a 75 the most. Let me know what good kits everyone uses for the s2k and other engine mods i should do with it.
I'll recommend what I use...ZEX! It is simple to install, and use. It's a dry kit, and it sprays at wide open throttle. If you want a 50ish shot, the only other thing you need are copper spark plugs...platinum won't work. If you want a 75 shot, then there are a couple of routes: 1) Apexi vafc, or 2) upgrade the fuel pump. This will keep your fuel ratio safe. If you want more than a 75 shot...you are taking a big chance with an expensive motor. Goodies you might want to think about with your kit include: a purge kit, pressure guage, bottle warmer, and remote bottle opener. All of these goodies will add a small chunk of change to the final bill. Here are some pics of my install...
bottle mount
notice the switches above the map light
and finally the purple box is the brains of the unit
I'm personally going with the VENOM KIT {VCN-2000}. Speak with Greg@Venon, his phone number is 1800-959-2865. Greg, is very helpful and very knowledgeable. The VENOM KIT, is probably the safest KIT out there.IMO!
