help and suggestion needed..
Old Jun 25, 2005 | 09:08 PM
asdfg123hk's Avatar
Default help and suggestion needed..
3 weeks of ownership and my rear end is damaged ...well i don't know who or what hit my car but it scraped some paint off...no dents but the color coat is peeling off and exposing the primer...
approximately 2cmx2cm area of paint peeled off..(approximately the size of our key fob)..
so i was wondering if i could patch it up with some touch up paint or it has to go to the bodyshop?
thanks
Old Jun 25, 2005 | 09:16 PM
jwa4378's Avatar
If it is the bumper, you should just repaint the entire bumper (if you want a clean look). You can use touchup paint, but it will stick out. If you remove the bumper yourself and take it into the body shop, they can get the paint code from the door sill tag and match it very closely (never perfect.....but if it is a good job, it will not be noticable). The best thing is that you SHOULD be able to drop the bumper off and pick it up at the end of the day.
Just my $.02
John
ps-If you car is Silverstone, of any metallic paint for that matter, if will be VERY difficult to match perfectly....Make sure they do it RIGHT.
Old Jun 25, 2005 | 10:53 PM
papa5murf's Avatar
berlina is probably the easiest of the s2000 colors to touch up
Old Jun 26, 2005 | 12:01 AM
asdfg123hk's Avatar
if i work with the touch-up paint..should i do multiple layers of paint?
by the way..prior to painting..should i do some sanding to smooth the surface?
thanks
g35s200o
Sep 20, 2010 12:46 PM
StEVEN_s2k
Mar 29, 2009 06:43 AM
ProV1
Sep 14, 2005 03:28 PM
Jaro
Aug 12, 2005 08:12 PM
Shvitz2k
May 26, 2004 02:28 PM
