Help! Wind Noise (not typical reasoning)
Old Jul 26, 2010 | 12:33 PM
F22C's Avatar
Default Help! Wind Noise (not typical reasoning)
Problem: Noise is coming from the front, above the rear view mirror. Yes, when I tug on it really tight, the noise decreases.
Background Info:
1)Previous to new Hardtop, no noise whatseover. (MY06 by the way) Perfect.
2)Got the new Hardtop, installed new strikers, and the new hardtop is perfect, no wind noise.
3)When I remove the hardtop and pull the soft top back on , there's a lot of wind noise now.
So, it's not a striker problem. I think it's because the HT is on pretty tight, the rubber seal at the top/front of the windshield, where the soft top connects, is compressed from the Hardtop, makes sense? So, the normal soft top isn't getting the original "seal" from the factory....anyone experienced this???
Thanks!
Old Jul 26, 2010 | 03:22 PM
xoz's Avatar
xoz
Is the HT OEM? I wouldn't imagine that the OEM HT would compromise the windshield seal. I'd say your HT is on too tight. Do you have shims under the front latches? Shims tend to ease the pressure on the windshield seal, whilst still maintaining a good seal on all the types of HT's. They also disperse the pressure on the HT corner edges preventing cracking/flexing in this spot.
Old Jul 26, 2010 | 03:26 PM
xoz's Avatar
xoz
also you may need to use some of that shinitse? lubricant now to plump up the windshield seal for when using the soft top.
Old Jul 26, 2010 | 04:13 PM
thetz99's Avatar
put 1/4 inch aquarium air plastic tubing on the softop hooks to tighten the pull. Cheap and effective.
Old Jul 26, 2010 | 04:20 PM
shamusodoofus's Avatar
I solved the problem by latching the top and after latching it, I retract the top and hold the button in place for 1 second to let the top pull back. My problem though is that the top sits a tad above the seals so the wind catches on and creates noise.
Old Jul 26, 2010 | 05:27 PM
F22C's Avatar
Mugen, authentic..so the fitment is perfect. What do you mean lubricant to plump up the seal? How does lubricant plump anything up? Thanks
Old Jul 26, 2010 | 06:03 PM
xoz's Avatar
xoz
"plump" as in figuratively no literally..
Old Jul 27, 2010 | 01:32 PM
F22C's Avatar
I've used all the shims and everything...still no dice...
Shinitsu grease? How/where would I even apply this??
Old Jul 27, 2010 | 02:35 PM
xoz's Avatar
xoz
just run it along the line of the windshield seal...esp. where you can hear the wind noise.
myclue
17
Dec 5, 2010 04:44 PM
jemje2006
Jan 11, 2010 01:11 AM
tbonesteak
Mar 2, 2009 01:05 PM
Moddiction
Apr 22, 2008 02:57 AM
baptistsan
Dec 11, 2003 09:15 AM
