hid
Old Sep 3, 2005 | 06:46 AM
DVSwetwilly's Avatar
Default hid
can i just put 8000k bulbs in my 02 S or do i have to buy some kind of kit to take the 8000k bulbs and where can i get some and what is the best hid bulb to get
Old Sep 3, 2005 | 07:15 AM
Paul S's Avatar
You do know that above 6000k, you'll be losing visibility, right? About 4500k is the brightest. 8000k is not only going to look like crap-pepboy-special colored bulb, but you won't be able to see too well, either. Stick with OEM, as it looks the best and performs well, IMO.
Old Sep 3, 2005 | 09:37 AM
steven975's Avatar
yea, at 8000 you're going to look worse than those cheap blue halogens.
Old Sep 3, 2005 | 10:59 AM
I want a more of a purple tint to my hid well i know that i would loose visibility would a 6000k give me that??
Old Sep 3, 2005 | 01:00 PM
steven975's Avatar
the audis and TL have what you want right?
those are on the higher temp range. I think they are like 5300K.
Old Sep 3, 2005 | 04:42 PM
JAXrsx's Avatar
I'm not sure what you are ultimately looking for, but I would not go higher than 6000k. For starters as everyone has said, you will lose intensity(and therefor visibility) if you go higher than the stock 4300k bulbs. The higher you go in the Kelvin range, the less performance you're gonna get.
The s2k stock setup does throw an intense purple color when viewed from certain directions. This is also what you're seeing when you observe the audi, bmw, etc headlights.
I was also under the impression that the higher K bulbs use a tinting on the actual bulbs (similar to the cheap halogen pep boys bulbs) which would cause the bulb to burn hotter and shorten its lifespan. If you go with 6000K you can get the Philips Ultinon bulbs which use a different salt inside the lamp to alter the color ouutput, and are supposed to be a good, durable product.
I would check out http://www.xenondepot.com. They have lots of info, and have sold a good deal of kits and bulbs to folks over at ClubRSX.
Craig
Old Sep 3, 2005 | 06:49 PM
EmuMessenger's Avatar
The stock bulbs on the S2k rock. Very purple around the borders, too.
Old Sep 3, 2005 | 10:35 PM
dyhppy's Avatar
bulbs are just plug and play, no additional hardware needed. but i wouldnt do it. i've been up to 8500k and it's all show no go.
Kengthao91
Jul 21, 2013 05:03 PM
world of debt
Feb 23, 2009 10:11 AM
icecreamballer
Jun 9, 2005 06:00 AM
kreuznach
Apr 27, 2005 08:17 PM
Bigeggroll
Feb 2, 2005 10:12 AM
