Highest grade of gas you've seen
Old Jun 16, 2001 | 12:25 PM
  #21
lvs2k's Avatar
Keep in mind that leaded gas will destroy your catalytic converter in short order.
Old Jun 16, 2001 | 06:38 PM
  #22
Jaysom's Avatar
Any race local race track should sell 100 unlead, as well as 110 leaded. It usually runs about $4.50 - $5.50/gallon.
As for Av. gas, from what I remember, it will make the engine run hotter and will kill your cat. converter.
Here in south Florida, you can get it at Moroso (west palm beach) and Homestead.
Old Jun 16, 2001 | 06:58 PM
  #23
lanbrown's Avatar
AV fuel is very bad for vehicles that stay on the gound. The fuel is designed for low RPM and reduced oxygen enviorments. The engines we have were not designed for AV fuel. AV fuel is not designed for out engines. Planes stay at a constant RPM, not large flucuations like we see. AV fuel can potentailly ruin your engine which is the worst case. The best case is your engine will run like crap.
Using a fuel with a higher octane rating then what is suggested will result in the same performance or even lower. Higher octane does not equl more power.
Think of it this way, lower octane has more potential power. Higher octane has less potential power. Why do higher performance engines have higher power? They have properties that require the higher octane to achieve it. Higher compression usually requires higher octane. If you used lower octane in the engine, it would knock and ping because the fuel would pre-ignite. The higher octane is is harder to ignite. The higher compression produces more heat and makes the mix easier to ignite.
If you still want to use higher octane fuel go ahead, but stay away from AV fuel. BTW, there have been a few studies that have shown higher octance fuel reduces the output of the motor.
Lance
Old Jun 17, 2001 | 10:07 AM
  #24
silverbullet's Avatar
Almost all the 76 and Citgo stations in Charlotte have 100 octane. They have it on one single pump station.
I wouldn't bother with the higher octane fuel, unless you have a supercharger. I noticed no difference in my S2000 and it actually seemed to run worse, but I definitely noticed an improvement in my 4Runner.
Old Jun 17, 2001 | 11:46 AM
  #25
Justin's Avatar
Originally posted by wdavis
Wheres the 100 octane stuff in Orlando guys? Best I have found is 93. Hook me up!
It's at the Speedway gas station right next to Holler Honda. You can't miss it.
Old Jun 17, 2001 | 08:44 PM
  #26
Utah S2K's Avatar
[QUOTE]Originally posted by Ray
[B]
Aviation fuel are leaded.
Old Jun 17, 2001 | 08:50 PM
  #27
Utah S2K's Avatar
http://www.bobscherer.com/images/Pages/Sta...20Lift%20Lg.jpg
...ah that's better
Old Jun 17, 2001 | 08:54 PM
  #28
Utah S2K's Avatar
Originally posted by S2K Fan
Unocal 76 in San Marino, Ca sells 100 octane racing gasoline.
It is on huntington drive
That would be on the corner of Huntington Drive and Monterey Road I believe. Grew up in San Marino. Lots of exotics
Old Jun 17, 2001 | 09:04 PM
  #29
Utah S2K's Avatar
I STAND CORRECTED:
Periodically we need to admit when we're wrong. I just checked my flight receipts from John Wayne Airport and find "leaded" AV-Gas I have made a mistake and so stand corrected. Thank you for the lesson learned. Hell I design flight contols and deal with hydraulics not fuel
Sorry for the confusion and thanks for the correction
Kyushin
Nov 13, 2009 09:18 AM
Sideways
28
Apr 30, 2005 12:40 AM
212swat
Jun 23, 2004 06:58 AM
rai
Aug 15, 2003 11:54 AM
simon2000
Dec 13, 2001 11:56 AM
