Hole in trunk
So I just bought a 2003 S2k and after I brought it home I realized all the problems with it. I guess one of the minor problems is a small pencil hole in the trunk where I can see the ground. My first idea was to rubberize the whole trunk but is there another like substance that I can use, so I can fill it in from the bottom and the whole trunk?
^that could be intentional! I personally drilled 3 holes in my trunk, although pin sized, to allow water to drain. It has been a common issue for s2k's to get water in the trunk underneath the tool kit. I think it is caused by the sealant around a drain hole or some type of vent around the rear bumper/trunk area that dries out and eventually lets water collect in the bottom. A simple solution is to drill a hole or two instead of having to remove the whole bumper etc.
Water in trunk fix
Water in trunk fix
don.cs.smith
Apr 20, 2016 06:07 AM
