Hole in trunk
Old Oct 20, 2013 | 03:43 PM
Mr S2000's Avatar
Default Hole in trunk
So I just bought a 2003 S2k and after I brought it home I realized all the problems with it. I guess one of the minor problems is a small pencil hole in the trunk where I can see the ground. My first idea was to rubberize the whole trunk but is there another like substance that I can use, so I can fill it in from the bottom and the whole trunk?
Old Oct 20, 2013 | 05:06 PM
darcyw's Avatar
got a picture of it. there may be a factory plug missing.
good luck
darcy
Old Oct 20, 2013 | 05:10 PM
cosmomiller's Avatar
Top Answer: 1
If you can't find a rubber plug that fits, cut off a piece of rod (threaded would do) that has a good fit, and seal it with JB Weld. Of course make it flush to the inside.
Old Oct 20, 2013 | 05:13 PM
MrKlean187's Avatar
^that could be intentional! I personally drilled 3 holes in my trunk, although pin sized, to allow water to drain. It has been a common issue for s2k's to get water in the trunk underneath the tool kit. I think it is caused by the sealant around a drain hole or some type of vent around the rear bumper/trunk area that dries out and eventually lets water collect in the bottom. A simple solution is to drill a hole or two instead of having to remove the whole bumper etc.
Water in trunk fix
Old Oct 20, 2013 | 05:18 PM
Mr S2000's Avatar
Well here the deal the previous owner I guess indented it tuning over something so I banged it back out causing I guess a hole. I'll get a photo.
Old Oct 22, 2013 | 11:20 AM
Car Analogy's Avatar
Maybe it was a hole used to pass a Nitrous line through?
In any case, like someone else suggested, try to find a rubber plug to put in there. Silicone it in place if it doesn't fit tight.
Old Oct 22, 2013 | 06:03 PM
Conedodger's Avatar
Find a small round head bolt and nut that fit the hole. Cover from the outside with under coating spray.
dkatzfey
Apr 30, 2017 05:24 PM
don.cs.smith
Apr 20, 2016 06:07 AM
S2KiLLa19
Apr 11, 2016 08:42 AM
.MM
May 15, 2007 07:59 AM
ZaToIChI
Jan 4, 2005 12:34 PM
