How To Correct For Rear Sliding Out
Old Jul 12, 2004 | 01:51 PM
  #21
Muz's Avatar
Muz
Former Sponsor
Originally Posted by SIIK2NR,Jul 13 2004, 06:41 AM
Brand new tires....i've owned the car for less than 1 month.
I definately understand that point of braking causing even more weight shift to the front further increasing the slide.
BINGO!!!! for the Rev Matching.....yeah....I didn't double clutch when I should have been. I don't always rev match but I'm going to start now as an everyday practice. I'm positive that's what it was, because I didn't WOT and even letting the clutch out normal on an uneven rev match would cause the spin/slide.
I appreciate everyones insight.....
BE SAFE OUT THERE!!
double clutch?
You don't need to double clutch in this car (or any modern car for that matter). If you want to rev match just blip the throttle between gear changes when downshifting.
Old Jul 12, 2004 | 04:09 PM
  #22
Fongu's Avatar
Originally Posted by Conedodger,Jul 12 2004, 04:38 PM
Downshifting should take place in a straight line BEFORE entering the corner.
Forgot to mention the textbook way of doing a turn. Shifting in mid-turn is just too risky and not the most efficient (or quickest) way to go.
1) Brake in a straight line.
1a) Downshift into correct gear for corner.
2) Turn in.
2a) Balance thottle.
2c) Head for turn apex.
3) After apex start to unwind steering.
3a) Start applying throttle.
4) Exit turn.
Rinse and repeat.
Old Jul 12, 2004 | 04:17 PM
  #23
SIIK2NR's Avatar
I thought double clutching is essentially rev matching. So what's the difference in clutching, going to neutral, rev matching, clutching and then selecting the lower gear vice........tapping the throttle, clutching selecting lower gear? Obviously one has an extra clutch step but is it essentially the same for the car?
Bliping the throttle is going to move you forward when the purpose of most downshifting is to stop. With double clutch your in neutral so the throttle blip is obsolete.
I suppose your method is effective when downshifting to accelerate.
Not looking for flames.......just info..... If I'm clueless......school me.....thanks.
Old Jul 12, 2004 | 04:32 PM
  #24
808style's Avatar
watch the best motoring video posted in this forum. it'll show you what people mean by "blipping" the throttle while you are downshifting. you are blipping the throttle while the clutch is in, not in gear.
Old Jul 12, 2004 | 04:48 PM
  #25
Fongu's Avatar
You defined the double-clutch correctly. The blip of the throttle puts the engine at the correct rpm for the next gear. The clutch out during neutral grabs the input shaft of the transmission and also matches it to the correct rpm for the next gear. So the engine, input transmission shaft and rest of the drivetrain are rpm matched for a smooth shift.
Modern passenger car transmissions are synchro-meshed. They have little gizmos that synchronize the input transmission shaft to the correct rpm when the gear is being pushed into the gate of the shifted gear. You really don't need the extra clutch since the transmission does the input transmission shaft matching. Less work for the driver, quicker shifting.
So double clutching includes rev-matching, but rev-matching doesn't necessarily mean double clutching. Semantics ain't they great!
Sometimes, it is good to double clutch to help out the synchros if they are getting worn and starting to fail or downshifting many gears or trying to downshift into first gear.
Old Jul 12, 2004 | 04:52 PM
  #26
hpark's Avatar
[QUOTE=SIIK2NR,Jul 12 2004, 04:17 PM] I thought double clutching is essentially rev matching.
Old Jul 12, 2004 | 04:59 PM
  #27
Chazmo's Avatar
I double-clutch for all my shifts, which is fun but entirely unnecessary. The key thing, with regard to this thread, is to rev match so that when you release the clutch in gear you don't get unexpected engine braking. I'm not sure if folks made it clear above, but that's what broke your tires free when you downshifted, SIIK2NR.
I agree with the other folks that it's best to be in the correct gear as you enter a constant radius turn. In the event of a decreasing radius turn, like we have here in Massachusetts, you have to use extra care in the S2000. You have to gradually slow down as you approach the tightest part of the turn, then keep constant thru it, then gas it up as you exit.
Old Jul 12, 2004 | 05:01 PM
  #28
Chazmo's Avatar
Oh, and FYI, if you like to downshift to first gear (I do), then I find double-clutching is the only way to do it. The synchros (or something) seems to block you from doing this otherwise.
Old Jul 12, 2004 | 05:02 PM
  #29
SIIK2NR's Avatar
Thanks for the lesson......I understand the concept of both and NOW know why double clutching isn't necessary......
appreciate all the helpful information.....
practice, practice, practice......
v2jack
Jul 29, 2009 12:34 PM
boyguan
Mar 31, 2008 11:52 PM
Carwyn
Mar 28, 2008 06:01 AM
xmugens2kx
Jan 20, 2004 03:16 PM
t.c.
Mar 13, 2002 03:06 PM
