How do I remove the stock air filter?
Old May 22, 2005 | 01:14 PM
jarod's Avatar
Default How do I remove the stock air filter?
Anyone know what the exact part # is for the K&N Drop-in?
Old May 22, 2005 | 05:28 PM
RazorV3's Avatar
2004 HONDA S2000 2.2L L4 F/I - All Automotive Air Filter E-2435
E-2435 Product Specifications
Product Style: Unique Air Filters
Base Outside Diameter: 7 in (178 mm)
Filter Re-Oiling Amount: 1.73 oz (51 ml)
Flange Length: 2.875 in (73 mm)
Flange Type: Centered
Height: 7.375 in (187 mm)
Top Material/Finish: None
Top Outside Diameter: 3.75 in (95 mm)
Top Style: Rubber
Weight: 1.9 lb (0.8 kg)
Product Box Length: 13 in (330 mm)
Product Box Width: 8.63 in (219 mm)
Product Box Height: 8 in (203 mm)
Old May 22, 2005 | 05:29 PM
nVz2000's Avatar
E-2435
Old May 23, 2005 | 02:34 AM
energetic's Avatar
I will answer to this topic's tittle... You just remove the airfilter box cover and pull off the filter. Then you just push the new one back on.
Oh... and you should leave the cover off the box!
Old May 23, 2005 | 06:56 AM
PdC's Avatar
PdC
It's on there pretty tight, I warmed up the rubber with a blow drier to make it easier to pull off. Notice the little pin, the K&N has a slot for it so you line up properly.
Also if you remove the airbox cover you gain sound and lose hp, so depends what you want.
Old May 23, 2005 | 10:38 AM
emrillive's Avatar
any pics of the the k&n?
Old May 23, 2005 | 12:07 PM
RazorV3's Avatar
basically the same shape as the OEM filter
S2KPUDDYDAD
Florida For Sale
Jan 30, 2013 04:26 PM
wwevo8
Oct 10, 2010 05:55 AM
aggie
Apr 22, 2006 06:54 PM
bulldogs2k
Aug 22, 2004 12:35 AM
biker1
Jul 30, 2001 10:41 PM
