How do you install CF hood?
Old Dec 12, 2003 | 09:27 AM
50cent's Avatar
Default How do you install CF hood?
Just curious. I am thinking of getting a CF hood. How do you install it? Do you have to replace the whole hood or does it come like a 'snap' on? Any pics or styles would you recommend? Thanks
Old Dec 12, 2003 | 09:39 AM
3ngin33r1's Avatar
You will be replacing the entire hood.
Old Dec 12, 2003 | 09:43 AM
E36Ap1's Avatar
Make sure you have someone help you. Or at least something or someone to hold the hood for you.
Old Dec 12, 2003 | 09:56 AM
WeevesGTS's Avatar
Yeah it's real helpful to have someone there to help you hold the hood while you bolt it to the hinges.
It is possible to do it yourself though. I've put normal hoods on a couple cars so if I can do it, anyone can. And carbon fibre is lighter.
Old Dec 12, 2003 | 09:57 AM
02spas2k's Avatar
first disconnect the hose from the washer nozzles. two people will make it 1000000000 times easier. there are 2 bolts on each side. take them out and just swop the hoods. very very simple.
MAtt
Old Dec 12, 2003 | 10:53 AM
TepEvan's Avatar
There is a thread in Under The Hood that discusses the install. You should check there.
Old Dec 12, 2003 | 10:57 AM
50cent's Avatar
thank you for all of your inputs folks. Much appreciated
BTW, how much do they typically cost?
Old Dec 12, 2003 | 11:17 AM
02spas2k's Avatar
there are some group buys that are going on now for about 500 plus shpping witch is about 100-120$.
Old Dec 12, 2003 | 11:25 AM
4IGS2000's Avatar
Spammer
Its very very easy..
simple:
remove the 4 bolts on the hood..
take off the washer nozzles and hoses
thats it!
you would need a friend to help
Old Dec 12, 2003 | 11:27 AM
turbo_pwr's Avatar
snap on http://forums.s2ki.com/forums/showthread.p...threadid=105024
