How often?
Old Apr 7, 2007 | 08:38 PM
ShowTime-the-Zzang's Avatar
Default How often?
How often do you all perform maintance on your S2K? Since the car is a high revving engine car...are their any "extra" maintance involved?
Old Apr 7, 2007 | 09:05 PM
Enthralled's Avatar
No,it's just like every other car.maintain it well and you'll be enjoying the car for a while....
peace
David
Old Apr 7, 2007 | 10:09 PM
CKit's Avatar
Check the oil often (like 1-2k miles).
Check the tire wear more often.
Check the spark plugs often if you're FI.
Old Apr 7, 2007 | 10:12 PM
Saki GT's Avatar
I check the oil with every gas fill up, you know, just like in the "olden" days. I also check to see if the tires look inflated.
Other than that, I follow the owner's manual.
Old Apr 8, 2007 | 07:25 AM
SFMarine0331's Avatar
Follow your owners manual....Keep up on the recommended maintenance. Check your fluid levels often. Same as tire pressure! Thats about it.
Old Apr 8, 2007 | 01:37 PM
gomarlins3's Avatar
Oil, filter, and spark plug change every 5,000.
Diff, clutch, brake, and tranny fluid change every 15,000.
Tires whenever they are needed.
Old Apr 22, 2008 | 06:51 PM
bam9382's Avatar
man thats pretty often to change your spark plugs... considering you only have to do it every 105000 miles... thats pretty wild and expensive...
I would just change your diff tranny and oil.. as directed by your manual..
Old Apr 22, 2008 | 09:38 PM
bumblebeeS2K's Avatar
if you're N/A and close to stock, there's nothing wrong with following the owners manual.
Old Apr 23, 2008 | 01:26 AM
nicokpe's Avatar
like usually, read the manual
Old Apr 23, 2008 | 04:46 AM
ian05s2k's Avatar
, just follow the manual if you are stockish
Deano_d
Jan 15, 2010 03:43 PM
si2ik
May 22, 2009 06:40 AM
intiMACY
53
Sep 24, 2008 06:06 PM
kidjetta
Feb 13, 2007 02:09 PM
redbullet
Mar 17, 2002 06:39 AM
