How is the VIN constructed?
Old May 10, 2001 | 11:29 PM
UKjasonm's Avatar
Default How is the VIN constructed?
Does anyone know how the VIN is constructed? This is following on from the earlier thread regarding TSB#54 (2001 Owners Read).
My (Belgian) car is 2001 and the VIN is JHMAP11301T200376 whereas one of the american guys qouted theirs as being JHMAP11431T002427.
From this is it possible to ascertain which car was made 1st?
My car makes a rattling noise when decelerating but I don't find it a problem, I presumed it was just driveshaft whine and the sound is there due to the driveshaft being in close proximity i.e. under the centre tunnel.
Thanks
Old May 10, 2001 | 11:32 PM
Schatten's Avatar
the last four digits is the build number. for instance, my '01 is #0477.
hope this explains the rest: https://www.s2ki.com/faqs/faq_vin.php
Old May 10, 2001 | 11:57 PM
UKjasonm's Avatar
Thanks for that, but I'm now a little more confused as my VIN is JHMAP11301T200376
JHM - Japan Honda
AP1 - S2000 - F20C1
1 - 2 dr Convertable 6 speed
3 - Whats does 3 mean if 4 is base model? is the Euro Model?
0 - Check Digit
1 - 2001
T - Tochigi
200376 - Numbers Seems high if its a sequential number.
Thanks
Old May 11, 2001 | 12:12 AM
Schatten's Avatar
the 20, not sure, that's what the "??" is for on the faq on s2ki.com. the last four digits in your VIN is the sequential number/build number/car number for that year.
Old May 11, 2001 | 01:17 AM
lvs2k's Avatar
Well, first, there's a little tiny Asian guy with a felt-tipped pin, then . . .
Old May 11, 2001 | 05:45 AM
S2000RJ's Avatar
Manufactorer, Make & Type of Vehicle
JHM: Honda Motor Co, LTD, Honda Passenger Car
Line, Boody and Engine Type
AP1: Honda S2000/F20C2
and S2000/F20C1
Body and Transmission Type
1: 2 door convertible/6 spd Manual
Vehicle Grade
2: for areas KE, KG
3: for areas KE,KG, KQ, KU
4: for area KH
Fixed Code/Check Digit
*: Not documented
Year
Y:- 2000
1:- 2001
Factory
T: Tochigi in Japan
Serial Number
000001 -
Engine Number
F20C1 - 1200001 (for KH, KQ, KU models)
F20C2 - 1000001 (for KE, KQ models)
Transmission Number
SCYM - 1000001
Applicable Area Code / VIN / Engine Number / Transmission Number List
Honda S2000 KE 6MT JHMAP1120YT000001~ F20C2-1000001~ SCYM-1000001~
Honda S2000 KE 6MT JHMAP1130YT000001~ F20C2-1000001~ SCYM-1000001~
Honda S2000 KG 6MT JHMAP1120YT000001~ F20C2-1000001~ SCYM-1000001~
Honda S2000 KG 6MT JHMAP1130YT000001~ F20C2-1000001~ SCYM-1000001~
S2000 KH 6MT JHMAP1140YT000001~ F20C1-1200001~ SCYM-1000001~
S2000 KQ 6MT JHMAP1130YT000001~ F20C1-1200001~ SCYM-1000001~
S2000 KU 6MT JHMAP1130YT000001~ F20C1-1200001~ SCYM-1000001~
Notes:
This information is taken from the Honda Shop Manual (Honda S2000 / S2000).
There is only one sequence number for gearboxes, so I'm afraid that the grind, etc are not related to a particular market!
There is a distinction between S2000 and the Honda S2000. I believe that this is also reflected by differences in external badging ie Honda badge above S2000 on the sides.
The shop manual also documents Vehicle Grades 6,7,8. These are deleted on an amendment dates May 99.
There appear to be no mechanical differences between the F20C1 and F20C2 engines, the differences are with Fuel, Emission Control and Electrical systems.
JHMAP1130YT is built as both Honda S2000 with F20C2 and S2000 with F20C1.
The Shop Manual does not document the countries covered by each Area Code. Any suggestions?
Interestingly, the Shop Manual also does not list the external colour / trim variations.
Old May 11, 2001 | 06:00 AM
UKjasonm's Avatar
Rob,
thanks for that (lots of detail). Do you work for Honda? where did you ge tht shop manual from?
Interesting about the engine, I always assumed that the JDM models had higher compression ratio's. I used to have a JDM Prelude VTEC which has 200hp compared to the UK 184hp and I was told this was down to compression ratio's due to the JDM car having a different (thiner) head gasket.
Hold on, I'm getting a bit of deja vu here, the UK engine is F20C2 (I think) and the US engine is F20C1 (?) so whats the JDM 250hp engine F20(A/B)?
Jason
Old May 11, 2001 | 06:46 AM
S2000RJ's Avatar
Hi Jason,
No, don't work for Honda, just a fan of the Stook. I tried to get the Helm manual, but it's not available in the UK and only covers the North American market. I got the shop manual from my local Honda dealer. It's pricey at about
Old May 21, 2001 | 01:57 AM
ianl's Avatar
Hi Guys
My VIN is JHMAP11301T200001
Am I right in thinking that this makes my car the 1st car built for the European market in 2001??? Neat!
Ian
funnyesq
Aug 18, 2007 07:10 AM
850glt
May 4, 2004 01:27 PM
chrysis
Feb 15, 2002 03:52 AM
Mack
Nov 20, 2000 10:40 AM
NJTom2000
Nov 2, 2000 12:00 PM
