How you do a burn out??
Old Oct 2, 2001 | 10:09 PM
S2peed's Avatar
Default How you do a burn out??
I see the guys in the track before they race they burn rubber was the right way to do this
Old Oct 2, 2001 | 10:13 PM
xfactor834's Avatar
I suppose you mean "how do you do a burnout"...
In which case...
Keep the brake pedal depressed, and slowly "accelerate". The car will want to jump foward, but as you slowly ease off the brake, your rear tires begin to spin...and if you put some oil underneath your tires, it'll smoke like you wouldn't believe.
It also helps if your tires have no treads (like racing slicks) and you do this on a perfectly smooth surface, unlike old asphalt.
Old Oct 2, 2001 | 10:32 PM
amartin's Avatar
Bah... roll over water or bleach and then raise the rpm's to 6+k.. and left-foot the clutch...you'll smoke as much as you want.
-- Aaron
Old Oct 2, 2001 | 10:35 PM
tokyo_james's Avatar
[QUOTE]Originally posted by xfactor834
[B]Keep the brake pedal depressed, and slowly "accelerate".
Old Oct 2, 2001 | 10:48 PM
kumar75150's Avatar
you have your left foot on the clutch and brake at the same time or something like that
i'm too sleepy to think right
Old Oct 2, 2001 | 10:50 PM
RT's Avatar
RT
[QUOTE]Originally posted by tokyo_james
[B]
This may sound dumb, but how do you depress the brake and accelerate and come of the clutch (assuming you are stationary when you start this) all at the same time?
Old Oct 2, 2001 | 10:52 PM
4IGS2000's Avatar
Spammer
UMMmm,
REV the car in 1st GEAR, DUMP THE CLUTCH
SIMPLE ENOUGH!
Old Oct 2, 2001 | 11:32 PM
naishou's Avatar
You don't.
Old Oct 3, 2001 | 04:25 AM
Allan Haggai's Avatar
Go buy a car with bags of bottom end torque and the accompanying beefy drive line components!
Old Oct 3, 2001 | 05:12 AM
Black & Boosted's Avatar
damn you guys need help...
Rev up to somewhere in the high RPMs (5500+) dump the clutch, the tires should spin, take your left foot and slowly push on the brake while you continue to press the gas. get on and off the gas, like when it gets near redline let off for a sec and then push it again, kinda pumping the gas, with your left foot on the brake to keep you still. when you decide you have done enough, let off the brake and push in the clutch.
done.
