I am stuck
Old Apr 2, 2011 | 02:37 PM
philo's Avatar
Default I am stuck
So I have a loose wire, it shuts down my radio. I have traced to to behind the rear center console near the passager roll bar. How do I remove the roll bar cover and the rear center console?
Old Apr 3, 2011 | 11:59 AM
Dead Serious's Avatar
honda didnt make it easy......the hard dog roll bar web site instal instructions can walk you thru it but i would try to get to it through the trunk if you can because it would avoid taking the interior apart. you shouldnt need to remove the roll hoop plasics to get to any wiring because the same trim you need to remove to get the roll hoops and the roll hoop plastics out will reveal the wiring. what ever you do dont try to remove the plastic trim from the roll hoops, instead unbolt the roll hoops with the roll hoop trim plastic in place.....but i dont think you should try to remove them. what makes you thing you have a loose wire under the console anyway?
http://www.bethania-garage.com/s2000_install.htm
Old Apr 3, 2011 | 12:58 PM
philo's Avatar
When I move the roll bar plastic the radio cuts out. I think it is the same wire that is attached to the aux power switch. It has the same symptoms; the radio display stays on but no sound.
jamesac83
Apr 10, 2015 11:18 AM
AZS2KDancer
May 16, 2014 10:42 AM
mandrocortes
Mar 10, 2014 06:46 PM
King_
Mar 9, 2009 10:02 AM
kats2k
Dec 7, 2006 11:22 AM
