Inside of front tires worn
Old Dec 4, 2004 | 06:41 PM
AmigaOS's Avatar
Default Inside of front tires worn
Inside of front tires are almost bald. Not many miles at all. I guess I should pay closer attention to them(like I do to the rears). Not many miles 32psi all around and the rears are like new. I replaced them all at the same time.
Old Dec 4, 2004 | 06:48 PM
Ooalloems2koO's Avatar
u meant there is camber wear in the front tires???
that is weird
Old Dec 4, 2004 | 06:56 PM
AmigaOS's Avatar
I was shocked. I thought something might be up because at times un-even road surfaces pulled at the front end.
Old Dec 4, 2004 | 06:58 PM
go check ur toe and camber angle...... is ur car lowered at all?
esracer's Avatar
That's not normal bro, I had that problem also. I just got a new set of tires and went in for an alignment today. I found out that my alignment was totally off, I had only 3 out of 8 points within specifications. My suggestion is that yours is off too, so take it in to get aligned and you should have more even wear. It noticable with the camber off, cause when I got home today I could see that the wheels were better aligned (less camber)
Old Dec 4, 2004 | 07:03 PM
AmigaOS's Avatar
[/QUOTE]I just got a new set of tires and went in for an alignment today.
That's the plan after I return from Texas next week...
Old Dec 4, 2004 | 09:52 PM
speed4tu's Avatar
An alignment should get it resolved
LT1
Jul 6, 2016 02:51 AM
thelemur
Dec 1, 2013 09:51 PM
Flite
Dec 22, 2010 10:56 AM
Alex_V
Mar 19, 2007 09:57 PM
B SweepeR B6
Oct 21, 2005 04:15 PM
