installing new exhaust, help please.
Old Feb 27, 2004 | 08:03 PM
C45P312's Avatar
Default installing new exhaust, help please.
finally getting around to install my exhaust, what tools and what sizes do i need to take the OEM exhaust off?
and as far as sizes i need to put the new one on, i could just size it off
thanks
-carlo
p.s. i do have jackstands
Old Feb 27, 2004 | 08:13 PM
dut's Avatar
dut
- can I take a guess and say 14...
- this is just a bump (and a +1 post), I don't have an s2000
wortham's Avatar
if this is the first work you've done on your car, you're starting in the right place. it's easy stuff.
the hardest part when i did mine was getting the stock one off the rubber dealies underneath. have some type of lube handy in order to help get it off.
other tools you might need are various sockets and a torque wrench (not necessary if you can feel a torque out but helpful nonetheless).
Old Feb 27, 2004 | 08:24 PM
C45P312's Avatar
wortham: yes, this will be my first work ive done to it personally. by chance you know what size sockets i will need? deep, short, etc?
Old Feb 27, 2004 | 08:45 PM
HARDtoTOP's Avatar
Yes, lube is needed. Almost impossible without it. WD40 works fine. If I remember, it's like a 10mm or 12mm. There is some sort of straight cross brace near the diff that you need to remove to drop the stock exhaust too. Hit the three bolts where the exhaust meets the cat with the WD40 or some PB blaster a few minutes before you start, they tend to get frozen easy. Other than that its a half hour job.
Old Feb 27, 2004 | 08:46 PM
HARDtoTOP's Avatar
Oh and to be safe if you are buying a new socket set, get deep. The threads MAY stick out too far near the cat connection. Cant remember, but just to be safe..
Old Feb 28, 2004 | 04:02 AM
C45P312's Avatar
well noted, anyone else?
Old Feb 28, 2004 | 04:40 AM
silvs2knvb's Avatar
if your car is stock height just get under it and do it (assuming you can fit) the exhaust bolts are 12 mm good luck
Old Feb 28, 2004 | 05:51 AM
RedY2KS2k's Avatar
Legal Bill did quite a write-up on removing the exhaust in Under the Hood. Find that thread.
Old Feb 28, 2004 | 07:29 AM
xviper's Avatar
For your convenience, here it is:
http://forums.s2ki.com/forums/showthread.p...threadid=173247
Oh, that 1/2 hour will turn into 1.5 hours (realistically), especially if this is your first project on the car. You won't just get under there and start turning nuts and bolts. The car won't magically put itself onto the jack stands and back down afterwards and tools don't magically put themselves away (clean) when you're done. You'll have prep time, clean up time, head scratching time when things don't go smoothly and when bolts are hard to get off or if they break (then you'll need hours to go get new ones). Rubber hangers that simply are a bitch to get off and onto the new exhaust.
That cross member has two different sizes of nuts and bolts and the cat bolt is possibly yet another size.
Having an assistance will make your project go a lot nicer.
808_JDM
Oct 8, 2010 10:59 PM
TexasGPWS2k
Mar 3, 2010 08:03 AM
TunedS2000
Jul 26, 2004 07:52 PM
BlueS2000Boy
Aug 7, 2003 12:16 PM
