Installing rear wing.
Old Nov 11, 2007 | 01:02 PM
Jamie_Murray's Avatar
Default Installing rear wing.
I've read the tutorial in the how-to section.
However I'm slightly worried about drilling a hole in my trunk.
To the people who have actually done it:
How long does it take to drill the holes?
Do i need special bits?
Do i need a special driver?
How much force is needed?
Any tips or tricks would be appreciated.
Old Nov 11, 2007 | 01:24 PM
nightcrawler7188's Avatar
-it takes about 10 seconds per hole, depending on how strong you are.
-the instructions should tell you the size bit you need
-the harder you push, the faster it will go.
don't worry. once you mark the spots you need to drill accurately, you should be fine
good luck
Old Nov 11, 2007 | 01:26 PM
It did not come with instructions!
What size bit should I start with and then which sizes should i jump and work up to?
Old Nov 11, 2007 | 01:31 PM
Raabjorn's Avatar
Here you go
http://www.hondapartsdeals.com/HondaInstal...runkspoiler.pdf
just try out bits by putting them through the holes in the spoiler. go a little smaller at first, see if it'll fit, then go one size bigger if it doesn't fit.
hopefully it at least came with a template that helps you mark the spots to drill
you didn't say which spoiler you got, but when i got my authentic honda wing it came with instructions and the template. also, if you look at the underside of the trunk, it has some holes punched there. those are common spots where spoilers mount.
Old Nov 11, 2007 | 02:06 PM
bracky's Avatar
Since it sounds like you have limited experience with a drill I'd practice a bit on a block of wood so you can get familiar with the tool.
Old Nov 11, 2007 | 04:11 PM
SIIK2NR's Avatar
Always start with a small bit to ensure you get the center of the hole with minimal drifting. Then increase your bit size as needed.
Recommend you use a highpower electrical drill vice a battery operated low amp drill.
If you use a larger bit with not enough power, you will chew up your trunklid.
Tim
Old Nov 11, 2007 | 04:23 PM
NOOOOOOOOOOOOO
I droped the screws into the holes while installing it!!!!!
=( Do I have to take the freaking trunk off to get them out?
Old Nov 11, 2007 | 04:26 PM
the holes you drill should go through to the other side, so anything you drop in should just be in the trunk
also be careful of the metal shavings on the trunk. blow them off or vaccuum them very carefully so that they don't scratch your paint.
Old Nov 11, 2007 | 04:45 PM
The screw you have to install to the underside of the spoiler, I tried to do it while the trunk lid was up, and it fell though into the trunk lid. Inside the trunk lid.
After repeated slaming of the trunk lid they eventually bounced out.
AS31
Aug 22, 2018 11:50 AM
The Engineer
Sep 28, 2016 11:15 AM
s2kcanuck
Jul 25, 2014 11:48 AM
Dize
Feb 8, 2012 08:57 AM
liquid_helix136
Mar 3, 2008 10:18 AM
