KG/MM race springs
KG/MM race springs
who is using this setup? how much does it lower the car? Would you say this is one of the best springs. There are Eibach, Espelir, RSR TI, etc.
I tried doing a search for these specifically but appartently you cant search for "kg/mm."
I've got this setup. It's pretty low.
It depends on what perch you set the ring to on the Konis. I set them on the lower perch with drops it another 1/2". Total drop i'd say is about 2.25"
One of the best springs around;they are progressive wonded springs;a little stiffer than OEM,with much better handling !
any of you running 18s? Right now I have the stock setup but I have 18 Works on order.
will it rub with that setup?
from what I have seen, the Eibach pro kit drop isnt enough for me.
got kg/mm race /w koni yellows. front is lower perch while rears on factory perch. makes the drop look even. shocks are set to 1/2 firm on all 4 corners and the ride is perfect IMO. i highly recommend this setup.
kgmm springs are dualrate so they give you the best of the both worllds...comfort and performance.
Just replaced my Kg,with G.C,.earlier this week,and I don't like them as much.
Will go back to my KG/MM this week-end(like tomorrow).
Anybody want a set of G.C,?
Originally Posted by mugenrsx,Aug 26 2005, 08:57 PM
How much do these go for and where can I get them?
Everybody swears by them,nowadays,because it is trendy.!!Looks good in a conversatoin:ie:I have a new set of Ground Control,and .....
Bear in mind,that they are only Eibach springs.
I much prefer my progressive,dualrate KG/MM.
