Leaking Window or Top
Old Jan 24, 2017 | 03:46 PM
jsteelman001's Avatar
Default Leaking Window or Top
Has anyone had a problem with their S2000 leaking around the windows, windshield or top during hard rain? Also, to get the best seal around the windows, is it better to roll the window up before or after shutting the door?
Old Jan 25, 2017 | 07:24 AM
Memo6453's Avatar
You can try shin etsu grease on the seals
Old Jan 25, 2017 | 08:35 AM
2poor2mod's Avatar
i agree, add shin-etsu grease to all of the seals. They are likely dried up due to age and have shrunk a bit.
Old Jan 27, 2017 | 02:50 AM
W00D's Avatar
I had this same issue. I used the above mentioned grease and also checked out the rubber ends on the corners of the softtop in the front. I got water leaking in there. I removed the ends (1 screw if each I recall) and checked things out. I used a tiny bead of RTV Silicon once I cleaned up the area and dried it. Not a leak at all since.
RobinA3
Aug 27, 2010 03:41 PM
NK04S2K
Nov 20, 2008 01:20 PM
Rickjames
Feb 28, 2005 02:21 PM
Project SSAP1
Nov 16, 2004 11:41 AM
Seks
Apr 25, 2003 05:07 PM
