Water leaking from above window?
Old Nov 15, 2004 | 02:37 PM
Project SSAP1's Avatar
Default Water leaking from above window?
does anybody else have this problem????? during hard raining my car leaks water from on top of the window between the rubber seal of the window and the soft top...its rather annoying...has anybody else had this problem and what can be done it fix it....please let me know something cause winter is coming up...
Old Nov 15, 2004 | 08:53 PM
anybody??
Old Nov 15, 2004 | 10:02 PM
808style's Avatar
does it leak in even if the windows are up? if its been raining and i roll down the window or open the door, a piss stream of water comes down from right where the window, top and windshield meet. it's pretty annoying because it gets in the car and on the window buttons. never had water leak in if the windows were up though.
Old Nov 15, 2004 | 10:53 PM
MattG's Avatar
Try a bit of shinetsu on the rubber, it helps to keep the seal in a good condition.
Old Nov 16, 2004 | 10:28 AM
yeah...it comes in when the windows are closed..its mad annoying..
Old Nov 16, 2004 | 10:46 AM
808style's Avatar
ok well then you have a problem. check the rubber seals to make sure they are not torn or deformed. i'm also thinking your top or window could be a little misaligned. you should try what MattG suggested first though and rub some shin-etsu grease on all those rubber seals.
Old Nov 16, 2004 | 11:41 AM
wing's Avatar
I had this happen once while I was driving, I rolled the window back down and up again and I've never had it before. It was all the way up at the time so not sure why it did that.
I've put some of that shin-etsu now as well.
jsteelman001
Jan 27, 2017 02:50 AM
Deleted03.15
Apr 20, 2015 07:51 AM
RobinA3
Aug 27, 2010 03:41 PM
Rickjames
Feb 28, 2005 02:21 PM
Seks
Apr 25, 2003 05:07 PM
