License Plate Holes on Front Bumper
Old 03-27-2007, 04:56 PM
mew002's Avatar
Default License Plate Holes on Front Bumper
I just took off my license plate holder and I noticed that the two sets of holes are different. One side has sockets that take in the screws but the other side did not (had a green clip instead). Is this normal?
Left Set of Holes
Right Set of Holes
Old 03-27-2007, 05:06 PM
Cubs2k's Avatar
no
Probably some front end damage in your car's history
Old 03-27-2007, 06:12 PM
FMINUS's Avatar
They should be both like the left holes.
Old 03-27-2007, 06:47 PM
psinex's Avatar
The bumper cover has threaded brackets held in place by sheet metal wedge washers. They do a substandard job of installing those brackets to the back of the bumper cover at the factory. When my S2000 was brand new, I removed the license plate housing and one of the brackets fell inside the bumper cover when I tried install the bumper plugs. I had to remove the bumper cover and reinstall the brackets by properly press fitting the wedge washers.
The left side of your bumper still has the bracket in place. The right side the bracket has fallen out and may still be in the bumper cover but is must likely lost.
Old 03-27-2007, 08:53 PM
gomarlins3's Avatar
Removing the bumper to replace the holders is not that hard or time consuming.
Old 03-28-2007, 09:51 AM
mew002's Avatar
The plugs should still fit in the holes right? I think that I'll just go with those instead.
Old 03-28-2007, 12:36 PM
hatch4raceb16's Avatar
Nope, the bumper plugs will not fit without the metal bracket behind the bumper cover. The plugs snap in using those brackets therefor if u try to put the bumper plug in that side missing the piece, it will just fall out.
Take your bumper off and see whats missing, then buy the piece, then install.
Simple.
Old 03-28-2007, 12:58 PM
mew002's Avatar
Is the bracket #10 on http://www.hondaautomotiveparts.com/auto/j...atcgry5=BUMPERS? Do I need to order any other parts to install it back on assuming that the entire component fell off? Thanks guys!
Darnold88
NES2KO Marketplace
09-22-2012 10:30 AM
bluerennfahrer
10-07-2010 01:17 PM
vti stu
09-06-2009 02:20 PM
GTS Jeff
07-29-2007 12:14 PM
cyafishin
04-11-2005 08:06 AM
Quick Reply: License Plate Holes on Front Bumper
