low idle
Old Jul 1, 2007 | 03:57 PM
nightcrawler7188's Avatar
Default low idle
when i'm at a stop, or the engine is in neutral w/ no gas, the engine speed drops very low, like it's about to stall, then comes back up to the normal idle speed. once in a while, it stalls. if i give it gas, it drops low again, then comes back up again. i already cleaned my MAP sensor, and did the MAP sensor whack, but neither of those made any difference. i tried disconnecting my battery for 10 minutes then reconnecting it and letting the engine run on its own for 5 minutes (to reset the ECU). that didn't work either. what should be my next step?
also i'm getting the CEL for a knock sensor malfunction. could this be causing the idle problem, or is that an isolated problem? also i can't find the knock sensor. i know where it is, but i can't get to it and thus haven't been able to see it yet. others previously suggested that i did something while installing my header (since the CEL came on minutes after), but i didn't touch anything under the intake manifold (where the knock sensor is located).
can you guys offer any help?
TIA
Old Jul 1, 2007 | 04:49 PM
CKit's Avatar
VAFC. Who's your tuner?
Old Jul 1, 2007 | 08:12 PM
^^never got it tuned
Old Jul 2, 2007 | 07:25 AM
Kenpo_S2000's Avatar
[QUOTE=CKit,Jul 1 2007, 04:49 PM] VAFC.
Old Jul 3, 2007 | 11:08 AM
BAJZ's Avatar
Had a similiar problem on my 00 with 41,000kms the dealer checked several things then finally called Honda tech centre, they said to check the value clearances. 7 values needed adjustment (problem gone)
Old Jul 3, 2007 | 03:33 PM
^^values or VALVES?
Old Jul 4, 2007 | 07:21 AM
BAJZ's Avatar
ok so I can't spell "VALVES"
Old Jul 4, 2007 | 01:22 PM
haha ok thanks
heymynameismark
Jan 2, 2016 05:13 AM
RevRanger
Jul 19, 2014 04:22 PM
simonix
Jun 15, 2011 09:01 AM
JspecVtec
Nov 14, 2007 06:11 PM
thrackley
Aug 12, 2004 10:00 AM
