Low Oil Question?!
Since we are talking about ap1's and oil burning, is it known why ap1's use more oil than most motors? I assume its getting past the rings? Is that right?
I am in the habit of raising my hood after I pull into the garage to remind me to check the oil cold before my next drive. Otherwise, I will forget to check it and get in trouble.
There is one member hear who modified the car by installing an external oil filter gizmo. The filter he uses is HUGE, not oem. I think he had an ap1 - not sure. But, I do remember he had over 300,000 miles on the motor with zero issues. Not sure if it was an additional filter, or if it replaced the OEM filter.
Might have been this filter: https://www.amsoil.com/p/eabp/#pills-home_0
Slalom44 may be the owner you are referring to, he installed an oil pre-luber on his engine it sends pressurized oil through the engine prior to start-up when parts tend to be low on oil (after sitting for a while), that reduces start up wear immensely, I think it can also provide added oil supply during oil starvation or low oil pressure events to help save the engine. I think his engine will go a million miles , that is a great setup, plus his oil filter set up is different in addition to this.
Slalom44 goes 40k miles on his oil. But he has a dual remote bypass filter installed + I think the stock filter. I'm not sure if he changes the oil filters during his long oil runs. But he has a AP1 and he does use oil, make up oil in his last 6 oil changes(240k miles) is 5.5 qts, 10 qts, 10 qts, 11 qts, 17 qts. and the last one 22 qts.
https://www.bobistheoilguy.com/forum...bypass.297133/
He puts a lot of miles on his S that's for sure. Hell, I only have 200k on my '06.
Rod
Rod
Here is a link to another thread with the details of the set up Slalom44 installed with parts identified and pictures of the installation.
https://www.bobistheoilguy.com/forum...0/#post-762080
You can also sand or sandblast the end of the dipstick to achieve the same result. One important thing is to check BOTH sides of the stick. It is possible to have oil on one side and have a different reading on the other.
I'd rather use fire than anything with the word sand in it. I don't want to risk putting contaminants into my motor, when there is an alternative that is actually easier.
Yes, you can clean the stick before dipping it back in place. But what if...
Its more work sanding or blasting followed by cleaning and inspecting, than to just use fire.
Some stuff was blocking my toolbox, so I just used the kitchen gas stove burner.
Why yes, the wife was indeed not at home when this took place. How did you know?
It is. And the correct brand is the brand I am using. I heard all the others burned off 10X faster, leaked out of ever crevice, caused complete engine failures and even causes peoples babies to be born naked. Oh wait ... I am NOT using Amsoil so I dont have to say all those things ....
