Miata + S2000 = M2000?
Old May 23, 2007 | 06:46 AM
  #381
GranPrix's Avatar
Originally Posted by Fyrestrike,May 23 2007, 06:35 AM
3) The engine/trans assembly got dropped as low as possible, then we bolted the mounts to the engine.
4) Then, we rolled the subframe around it (away from the chassis) and lined up the two bolts that attach the mounts to the subframe (this took a while but it worked).
You got these two backwards.
We bolted the mounts to the subframe first then we slid the subframe/mounts from the front of the engine towards the rear and then bolted the mounts on.
Old May 23, 2007 | 06:54 AM
  #382
GranPrix's Avatar
That's not the pic I remember you taking, there's another!!!....
Old May 23, 2007 | 07:01 AM
  #383
PrOsPeCt S's Avatar
yea there is another pic
Old May 23, 2007 | 07:21 AM
  #384
Fyrestrike's Avatar
Doh! Edited!
We tried it so many different ways I don't even know which one worked!
Old May 23, 2007 | 10:19 AM
  #385
buzilanga's Avatar
Nice work, 26 days in the build already hehe, hope that when I'm back I have time if you guys are working to come by and see the baby beast.
Old May 23, 2007 | 10:32 AM
  #386
Fyrestrike's Avatar
There's actually alot more. I should name them updates rather than days. Sometimes I combine days for the sake of continuity and because we'd stop in the middle and continue the next day.
Old May 23, 2007 | 11:43 AM
  #387
Jdmapl's Avatar
Nice build
Old May 29, 2007 | 12:09 AM
  #388
ahmed.omar's Avatar
hi fyerstrike this is ahmed from miata.net, i have a qustion about the build, will it be ok if i raise the engine to clear the crossmember?
Old May 29, 2007 | 06:14 AM
  #389
Fyrestrike's Avatar
No, in order to clear the Miata's subframe with the stock F20C oil pan you'd have to raise the engine about 4 inches. This won't work because a) the trans will hit the tunnel and b) the motor mounts won't line up, and c) the hood won't close. I'm sure there are other reasons but the conclusion made was that it was much easier to hack up the Miata subframe (which I think you mentioned you can't do in your country).
Old May 29, 2007 | 09:54 AM
  #390
ahmed.omar's Avatar
Makin a hood scoop is not a problem, btw i bought an engine, trans, diff, ecu, wiring loom, instrument cluster all of a 2005 s2k. so yeah hood can be modified, 4 inch higher mounts and cut trans tunnel. That is not a problem as long as there is no cuts or welds on the cross member. A 4 inch lift will not cause bad handling or things like that? i will also try to make an adapter to hang the diff, customize the ppf rather than welding a support bar in the chassis.
