Modifying Exhausts
Old Aug 19, 2005 | 06:27 AM
sweetj's Avatar
Default Modifying Exhausts
Does anyone know what spugen exhaust would sound like if you cut out the resonator? Has anyone done it?
Thanks
Jerrianna
Old Aug 19, 2005 | 10:49 AM
RoaringVtec's Avatar
Don't and if you do keep it around because you'll want to put it back on. I took the stock exhaust's resonator out and it sounded nice but then after a while i guess the exhaust "breaking in" i started to get resonance, really bad at around 3.5k and up and lots of vibration and humming noise inside cabin.
Old Aug 19, 2005 | 11:23 AM
sweetj's Avatar
Thanks I read your post about that earlier but my resonator has gone bad. This would be on my Spugen exhaust
Old Aug 19, 2005 | 11:44 AM
If the stock exhaust got the resonance, vibration and humming noise inside the cabin i would imagine and aftermarket exhaust would be worse. take it off and just weld a pipe in it's place but do keep the resonator because you may want to sell it. Also read my post about "Exhaust drone explained" it talks about resonators and things like that.
Old Aug 19, 2005 | 12:22 PM
thetz99's Avatar
If you have a stock exhaust and you are getting drone after taking off your resonator, you have a leak in your exhaust somewhere, probably on the welds on the replacement pipe for your resonator. You should check that cause it is common for the tech to be too lazy to weld on the top edge and the weld will break.
If you take off the resonator for the spugen, be prepared for a Invidia like drone, probably 90% of how an Invidia in the cabin. The sound behind the car is awesome tho. It's the tradeoff...do some soundproofing when you do it to enjoy it.
Old Aug 19, 2005 | 01:18 PM
johnyboy32's Avatar
I (and many others) have removed the resonator and are happy with the results. Just like picking an aftermarket exhaust it is a matter of taste.
Old Aug 19, 2005 | 01:31 PM
WVtwisties's Avatar
anyone run this setup...
stock exhaust with testpipe and resonator removed????
That would be interesting.
What would it sound like?
What would it smell like?
Old Aug 19, 2005 | 02:05 PM
Wisconsin S2k's Avatar
moving to S2000talk. general product questions go there.
s2kjdm
Feb 9, 2008 12:51 PM
BananaRacing
Aug 8, 2007 03:29 PM
xstremer
Feb 13, 2006 03:04 AM
RoaringVtec
Aug 21, 2005 07:11 AM
WRS2K
Feb 7, 2005 05:25 PM
