Muzmat floormats for 2002 S2K
Has anyone ordered floormats from muzmat for a 2002 model? Mine arrived this week. I ran into a couple of problems:
- I ordered mats with eyelets to fit the 2 anchor posts in the driver side floorpan. The driver side mat arrived with 1 eyelet. It does not even go over the anchor post; it's about 1 inch offset.
- Both mats are really tight; there is no play side to side (not really a big deal, I was just wondering if this is normal)
I've just contacted muzmat, but I wanted to know of any experience with 2002 models. Did they add an extra anchor post this year? Did they move the position of the outside anchor post?
Thanks!
Thanks!
I received my mats about 3 weeks ago, it came with 2 eyelets on the driver's side only. It was a tight fit and I mentioned to Muz that it really hugged the left side more so than the right (console) side. Maybe my eyelets were drilled a bit more left than the '02 that Muz measured from. I don't know. Hope this helps. Oh, I bought the more expensive luxury mats but that shouldn't make a difference with the location of the two eyelet holes.
Thanks for the info. Do you have a 2002 model? Do you know if the eyelets (number, position) have changed since 2001? I noted on my order to Muzmat that I had a 2002. Thanks in advance.
they need to fit tight to keep them from moving around...
(side to side)
after they are a bit older they start curling up at the sides, so you have to uncurl them- still much better than the honda mats
(side to side)
Rick Hesel
Sep 14, 2002 02:13 AM
