My passenger window wont go down!!!
Now before you jump to conclusions. It does go UP and the passenger side works fine...up and down. So its not the child safety switch.
I have yet to test the top rolling it down if it does then its probably in the switch its self. My installer is leaving right after work so I wont be able to have him test the switch today
Just wondering if this has happened to anybody else and what the resolution was.
Thanks
Thanks
At least its stuck going up and not stuck down
With my luck that would happen to me on the same day that Jupiter aligned with Pluto and the hundred year storm hits north texas and turns it into Bangledsh during monsoon season...
Hope its a simple problem.
Tsu~
Tsu~
Originally posted by S2peed
i know the problem just go to the switch of the windows there is a switch that goes left and right just turn it to the right and it should work. it happan to me so dont feel bad
Look above.
Pinky - If the passenger side window switch works, but the driver's side doesn't, that suggests that there is a problem in the driver's side switch. It may be as simple as a loose connection to the switch, or as bad as needing a new switch assembly. I'm pretty sure that with all of the audio upgrades you've done, you know how easy it is to take a door panel off. Once the switch is accessible, check that there is power coming to it and that it switches properly (easily done with a volt-ohm meter). If that's not the problem, then
. Good luck.
. Good luck.
jammer2209
Mar 15, 2011 12:49 AM
