My Stook is shedding!!!!
I noticed this the other day:
When I put my top up and closed the latches, I saw metal shavings fall from them in the sunlight.
Is everyone else experiencing this wear on the metal where the latches connect to the windsheild? Should I be doing something to prevent this?
Thanks in advance
And while I'm here, can someone post instructions for taking the center console apart to get the build date? Thank you
Is everyone else experiencing this wear on the metal where the latches connect to the windsheild? Should I be doing something to prevent this?Thanks in advance
It a standard problem that everyone has. I remember someone posting a solution to this a while back. Something like using that "heat-shrink" wire insulation. Put it on there and bake it with a hair dryer.
Originally posted by Utah S2K
To remove the center console to get the build date......DON't!
1) Step one
Open drivers door
2) Step Two
Read build date in door jam.
1) Step one
Open drivers door
2) Step Two
