My Stook is shedding!!!!
Old Jun 14, 2001 | 10:40 AM
SiK182's Avatar
Default My Stook is shedding!!!!
I noticed this the other day:
When I put my top up and closed the latches, I saw metal shavings fall from them in the sunlight. Is everyone else experiencing this wear on the metal where the latches connect to the windsheild? Should I be doing something to prevent this?
Thanks in advance
And while I'm here, can someone post instructions for taking the center console apart to get the build date? Thank you
Old Jun 14, 2001 | 10:45 AM
brandonb's Avatar
I'm experiencing the same problem with mine, I figured it was somewhat normal. Any ideas?
Thanks,
-Brandon
Old Jun 14, 2001 | 10:57 AM
FlyingPig's Avatar
I don't think you have a choice.
That's the way it is.....bad design.
Old Jun 14, 2001 | 11:11 AM
Mr. Bill's Avatar
Try a little grease in there
Old Jun 14, 2001 | 11:48 AM
krhorrocks's Avatar
It a standard problem that everyone has. I remember someone posting a solution to this a while back. Something like using that "heat-shrink" wire insulation. Put it on there and bake it with a hair dryer.
Old Jun 14, 2001 | 03:54 PM
Utah S2K's Avatar
To remove the center console to get the build date......DON't!
1) Step one
Open drivers door
2) Step Two
Read build date in door jam.
Old Jun 14, 2001 | 03:57 PM
Utah S2K's Avatar
1) Step one
Open drivers door
2) Step Two
First Line of information on the white label just below the Door Catch on the body side
tylorweaver
Apr 12, 2016 04:36 PM
40watts
Feb 8, 2009 12:24 PM
mbongiovi
Nov 6, 2004 02:29 PM
jedwards
Feb 28, 2002 07:08 PM
Wendysman
Nov 30, 2000 02:29 AM
